The Switches In My Garage Randomly Stops Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 12:42 AM   #1
The switches in my garage randomly stops working
This has been happening for a few months, on and off, but lately it's been happening really recently. The problem is that time to time, there is no power in my garage. I've checked the breaker panels, but there is nothing wrong with it, I've tried to switch the breaker on and off but it wouldn't work. I'd like to know if it's my breaker panel's fault or something else.
Thank you
kk1234 is offline   Reply With Quote
Old 01-01-2012, 12:55 AM   #2
Julius793's Avatar
Thank you
The breaker can be faulty take a tester and test it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-01-2012, 01:00 AM   #3
Will do, thank you
Old 01-01-2012, 01:05 AM   #4
Oh, I have another question, if I were to change the breaker, should I use a higher powered one? Right now I am using a 15AX breaker and I am wondering if the reason it won't work is because it isn't higher enough because, you know, it's Christmas month and I've been using a lot of energy with Christmas lights and such.
Old 01-01-2012, 01:15 AM   #5
Julius793's Avatar
If you mean higher amperage absolutely NOT that can cause a fire if you mean a more expensive one, if you want and if it's made for your panel. Btw your Christmas lights shouldnt affect the breaker
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
Light switches not working marc633 Electrical 7 07-22-2008 05:34 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 10:32 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
