Switched Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2014, 12:12 PM
Rewards Points: 2
Smile
Switched lights
In my hallway I have 3 lights, all switched from 2 switches (1 at each end of the wall) Most of the time I only need 1 light, not all 3 at the same time.
Would I need to run a separate circuit and switch each individually, or could I replace or add some type of switch at existing location that would allow me to operate each individually?
sixtz4me is offline
Old 10-25-2014, 12:22 PM
Rewards Points: 3,396
remove or loosen the bulbs in two fixture so only one lights
ritelec is offline
Old 10-25-2014, 12:42 PM
A "Handy Husband"
rjniles's Avatar
Rewards Points: 96
Why? Do you think you will save $$.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline
Old 10-25-2014, 03:26 PM
dmclean701's Avatar
Rewards Points: 152
For the cost of installing new wire and switches, you could buy LED lights, then use all of them.
dmclean701 is offline
The Following User Says Thank You to dmclean701 For This Useful Post:
rjniles (10-25-2014)
Old 10-25-2014, 06:52 PM
dmxtothemax's Avatar
Rewards Points: 7,606
If all three lights are on the one circuit ?
Then you cannot control them individually ,
Unless you run new wires.
What's your concern ?
dmxtothemax is online now
Lights on one circuit flicker now after tripping breaker shootmenow Electrical 8 04-13-2013 11:44 PM
lighting wiring diagram help, changed fan with lights to fan w/out and recesed lights snowmanZ Electrical 11 02-09-2013 06:38 PM
HELP!! 3 way wiring for lights with 3 zones BigSi Electrical 7 01-28-2013 11:10 PM
lights blinks when another appliance is switched on quanpenter Electrical 3 12-04-2012 11:38 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
