Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 10:26 PM   #1
switch wiring
Hi, In my kitchen i have 2 lights controlled by 1 switch. I want to add a 2nd switch in the same box to operate the lights separately. What info do you need to help me? Thanks Ed
forsale69 is offline   Reply With Quote
Old 01-05-2010, 10:44 PM   #2
You probably just need to run 1 new wire from the switch electrical box to one of the lights you want to control and do a little rewiring at the fixtures.
Is there attic access to the two lights?
Can you run an additional wire down the wall to the switch electrical box?
(To the gurus and diagram drawers here... Basically run wire from new switch to one fixture, then rewire existing wire to that light to not be switched by the other switch and switched by the new switch is what I am thinking...)
Billy_Bob is offline   Reply With Quote
Old 01-05-2010, 10:49 PM   #3
Yes there is attic access and everything is in conduit so i can get from the switch to the fixture without to much trouble. Just want to wire it correctly. I work best with pictures if you or someone could draw me a picture. Thanks
http://www.electrical-online.com/ima...eceptacles.gif
This link shows what i think i have.
Old 01-06-2010, 09:08 AM   #4
Rewards Points: 2,800
Can you get another wire (not green) from the switch through the conduit to light box #1 (on the left in your diagram)?
Remove just the red wire from the wire nut in light box #1 and connect it to the new wire you just strung.
Down in the switch box connect the new wire to switch #2. Take the white* wire off of the existing switch and wire nut two short lengths of wire to it. Now you can connect the other terminal of both switches.
* For individually strung wires in conduit, neither of just two wires entering a switch box may be white. You might take the opportunity now to replace the white wire with a colored wire (not green).
Sometimes it is easy to get a new wire down a conduit by attaching a string to one of the existing wires and pulling that wire out the other end. Then attach the new wire and pull both wires back through using the string.
For those eavesdropping, if you run a conduit or a cable directly from the switch box to light box #2 as a switch loop, two conductors are needed (switched hot and its own hot feed) and they are connected to switch #2 without pigtailing to switch #1. In other words do not make a switch loop as a triangle with hot feed (white in the diagram as linked) from box #1 and switched hot directly to box #2.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 01-06-2010, 10:36 AM   #5
You would disconnect the red wire at the second light and cap it in the box, then run a new black wire from that light to the new switch.
hayewe farm is offline   Reply With Quote
Old 01-06-2010, 11:03 AM   #6
Or run new red from switch to first light, disconnect red from blacks and connect reds togeather. Which ever runs is easiest
switch wiring-power-20in-20to-20lights-20one-20switch-20leg-20for-202-20lights-20power-20on-20to-20receptacl.jpg
Old 01-06-2010, 10:58 PM   #7
THANK YOU...THANK YOU...THANK YOU!!!!!!! The drawing was excellent...had it done in just about an hour. I owe you a drink!!!!
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
wiring in line light switch on power cord basicbrand Electrical 4 12-08-2009 09:36 AM
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 06:03 PM
Wiring of a contactor LC1D091o to a daynight switch kalulu Electrical 3 05-01-2009 02:09 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 07:47 PM
