Switch To Switch And Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2010, 10:11 AM   #1
Rewards Points: 182
Switch to switch and outlet
Hey guys,
Looking to swap out a current switch that works a kitchen light for a switch and an outlet combo unit..... I have purchased this unit here: http://www.homedepot.com/Electrical-...atalogId=10053
Now in the pic below - these are the wires I have:
Top left: nothing
Top Right: Red
Bottom Right: Black
Bottom left: white
Now how do I get my new outlet/switch installed???
tb582 is offline   Reply With Quote
Old 04-30-2010, 10:50 AM   #2
Just call me Andrew
Rewards Points: 1,032
Is this a 3-way switch (does another switch also control the same light?) Do you have any wires in the back of the box, or just those 3?
If you only have those 3 wires, you probably cannot put an outlet there because you do not have a neutral wire. The switch is being used in a switch loop.
Andrew
secutanudu is offline   Reply With Quote
Old 04-30-2010, 11:07 AM   #3
Rewards Points: 182
yes there actually is anothe switch but its current disconencted as my fridge ended up going in front of it (long story) - so those wires are just tied off and a cap is where the switch used to be....
Old 04-30-2010, 11:18 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 960
How many and what color wires are capped?
also looking at the link, you can not use the combo switch.
You need a 3 way switch and a gfci, and I'm not sure they are made.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 04-30-2010, 02:58 PM   #5
Rewards Points: 182
Hmm thats a good question - honestly I dont know, I'll move the fridge tonight and take a looksee...
Old 04-30-2010, 05:31 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 23,982
Is this in a kitchen? You can't do it to code if it is, even if you have the wires. Small appliance circuits must be 20 amp and no lights are permitted to be on them.
Old 04-30-2010, 05:48 PM   #7
Master Electrician
Rewards Points: 5,082
Why would you consider this a small appliance circuit?
brric is online now   Reply With Quote
Old 04-30-2010, 07:35 PM   #8
Super Moderator
joed's Avatar
Because he mentioned the other end is behind the fridge. The fridge is usually in the kitchen.
Old 04-30-2010, 07:43 PM   #9
Master Electrician
He said the other three-way switch was behind the fridge. Not all kitchen circuits are small appliance circuits.
Old 04-30-2010, 08:43 PM   #10
If you don't want to have the 3 way function, you could rewire the circuitry in such a manner, to allow the use of the combo switch that you have selected.
It may require removing the switch from the box behind the refrigerator and making the changes there.
Or its possible that the changes would be made in the light outlet box!
It depends where the power is fed to. Sometimes it goes to a switch box, in other cases it will go directly to the light!
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 06:25 PM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
