Switch Rules - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 04:12 PM   #1
switch rules
Just noticed a sticker on the side of a dimmer switch i just installed, which says "terminal for 3 way application only, single pole use only". If I'm not using it for a 3 way switch, do i really have to replace it?
DianaMikas is offline   Reply With Quote
Old 09-30-2009, 04:17 PM   #2
Code05's Avatar
Rewards Points: 1,104
Not if you installed it correctly. A 3 way can be used as a single pole if wired right. I have seen dimmers made made for both. Usually a little more expensive.
Code05 is offline   Reply With Quote
Old 09-30-2009, 04:26 PM   #3
That's great. I did install it correctly. Thank you.
Old 09-30-2009, 04:35 PM   #4
Code05's Avatar
You are welcome. Any other questions?
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
