Switch Plates - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 02:20 PM   #1
kimbalee's Avatar
Question
Switch Plates
Are there switch plates that extend out from the wall? More like a box? (I havenít found any) I have installed a light switch timer, and canít seem to fit all the wires and the switch into the electrical box so that it is flush with the wall.
Any ideas? Thanks
kimbalee is offline   Reply With Quote
Old 10-10-2009, 04:08 PM   #2
Journeyman Wireman
Rewards Points: 150
How many cables/wires are entering the box? You may have to remove the old box and replace it with a deeper "old work" box to accommodate the wiring and the bulky dimmer.
Jupe Blue is offline   Reply With Quote
Old 10-11-2009, 01:05 PM   #3
They do make extenders but that won't look to good because you will have the same problem. I agree with Jupe, I would pull the box and replace with a deeper cut in box to hold all the wires.
ausblake is offline   Reply With Quote
Old 10-13-2009, 11:21 AM   #4
J. V.'s Avatar
Rewards Points: 348
Can you use one of these. Not pretty, but will extend your box out 1.5 inches.
If it worked before you worked on it. You did something wrong.
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
