Switch Placement Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 10:37 AM   #1
Rewards Points: 262
Switch placement question
I am preparing to install recessed lighting on a new circuit in my living room. The room has an exterior entryway plus two interior doorways. Currently, the exterior entryway has a rocker switch controlling a 15A receptacle (with a table lamp plugged in).
Does code require that I install switches to control the recessed lighting at all three entry points, since a switched outlet is already present by the exterior entryway door? I have a low-slope attic and penetrating the top plate of the exterior wall from the attic is very difficult, so I'd rather not deal with installing switches on that wall if I can avoid it (plus it saves me the cost of a third lighting . The other two entryways are near the center of the attic, so there's plenty of headroom to work there.
clashley is offline   Reply With Quote
Old 12-22-2010, 01:20 PM   #2
Master Electrician
Rewards Points: 5,082
The NEC does not require it. Local or state building codes might require it.
brric is online now   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Question about neutral wire through wall switch guitarmonster Electrical 33 08-08-2010 09:51 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Wiring question: One switch controls 2 outlets mneumann Electrical 2 12-11-2009 12:49 PM
automatic transfer switch question Jeremy Hillary Boob, PhD Electrical 5 11-19-2008 10:36 AM
