Switch Nightmare - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 05:20 PM   #1
Switch Nightmare
I have power going to the light switch
The plug is controlled by the light switch
Power going to the plug in. Plug does not work
Switch also controls the light.
No power to the light
How do I fix this nightmare
ccnw is offline   Reply With Quote
Old 09-04-2010, 05:25 PM   #2
Was it broke before you touched it? Were you just replacing the switch? Do you have pictures?
macdonald is offline   Reply With Quote
Old 09-04-2010, 05:29 PM   #3
It was working find for years until the breaker blew one day.
Ever since then not light and no plug
Old 09-04-2010, 07:25 PM   #4
Rewards Points: 1,120
Let me see if I understand what you are saying:
The wall switch controls a receptacle (an outlet) and a light fixture.
Now, neither the receptacle or the light fixture are working.
Is this correct?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 09-04-2010, 07:38 PM   #5
Rewards Points: 150
Have you checked if your light bulb is loose? The starter may not be working anymore.
MagicalHome is offline   Reply With Quote
Old 09-04-2010, 08:15 PM   #6
This is correct
There is power in the switch
Power to the outlet, but does not work
Old 09-04-2010, 08:40 PM   #7
I=E/R
a7ecorsair's Avatar
Originally Posted by ccnw View Post
This is correct
How are you testing for power? Do you have a volt meter?
a7ecorsair is offline   Reply With Quote
Old 09-04-2010, 09:00 PM   #8
Rewards Points: 1,192
Neutral?
bobelectric is offline   Reply With Quote
Old 09-04-2010, 09:04 PM   #9
Yes, The volt meter light comes on at 110V
Comes on when I put it to the swich
Comes on when I put it to the plug
Does not come on when I put it to the light
Old 09-04-2010, 09:06 PM   #10
Originally Posted by bobelectric View Post
Neutral?
Neutral????????????
Old 09-04-2010, 09:30 PM   #11
Super Moderator
joed's Avatar
Rewards Points: 23,990
Comes on when you put to the switch and what? If you are putting it to ground then the neutral may be open.
Since the breaker tripped I would open the receptacle and the fixture and check for burnt connections that may have shorted to ground to trip the breaker.
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
