Switch/light Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 08:40 PM   #1
switch/light wiring
Here is my setup:
My light switch box (I am putting a regular switch in (not a three way)), has three wires coming in:
one is from my light
one is from the hallway light switch (which is a three way switch)
one is from the bedroom light switch
(ALL of these wires have a black, white and ground (no red))
My light (the one with the wire going into my light switch setup, has two wires going into it.
One is from the light switch (above)
The other is an old wire (I assume it is the one feeding the power)
How do I hook up the light switch, and how to I hook up the light?
I already tried hooking all blacks to blacks, whites to whites and pigtailed...doing this, flips the breaker when I turn on the light.
I was thinking of putting the white wire from my switch that is going into the light to the black wires. But I wanted to run that by someone first before I tried it.
Thanks for the help...
remodel35 is offline   Reply With Quote
Old 12-19-2009, 08:51 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 396
Connect all the whites together.
Connect all the grounds together.
Connect the power black to the other switch black and to a black pigtail.
Connect the pigtail and the fixture black to the switch.
Old 12-19-2009, 09:00 PM   #3
300zx's Avatar
Post
Look at the second setup in link if you have 3 wires in a box and 3 lights sounds like the power is in the light box and all you havhttp://www.crsupport.us/144.htmle is switch loops.
300zx is offline   Reply With Quote
Old 12-19-2009, 09:06 PM   #4
Can you go into more detail......how to connect inside my switch, and how to connect inside my recessed light....I could not tell from your posting what one you were trying to tell me about
Old 12-19-2009, 11:22 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 396
Well you only descried wires in the switch box so I was telling how to connect in the switch box.
If you can't understand what I wrote then I think you need an electrician. I can't make it any plainer.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
