Switch Box And Cover Plate - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2014, 10:09 PM   #1
Rewards Points: 113
switch box and cover plate
After not being able to find locally a single gang box of 22.5 cu in. at the big box stores, looks like I will have to us a 25 cu in. 2 gang box which I can do but I can't find a 2 gang brass cover plate that is toggle switch (or outlet) on one side and blank on the other. Does anyone have a source for the above described brass cover plate?
Captflx is offline   Reply With Quote
Old 04-16-2014, 11:46 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Gonna be a tough one to find. Brass is out of style and consequently, the selection of parts isn't what it once was. That can even be tough to find in plastic. Can you put a mud ring on and patch the wall? You can use a single gang mud ring on a double box.
iminaquagmire is offline   Reply With Quote
Old 04-17-2014, 12:19 AM   #3
Oso954's Avatar
Rewards Points: 1,852
Don't know what color brass you are looking for, but here are a couple of choices.
http://www.switchhits.com/configuration/toggle-blank
http://www.kyleswitchplates.com/1-to...nk-wall-plate/
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
iminaquagmire (04-17-2014)
Old 04-17-2014, 02:34 AM   #4
Rewards Points: 338
Easier to find than I thought. Still would use the mudring if there's only one device in the box. It always looks like a mistake or something's been messed with where there's a half blank plate. Just my opinion.
Old 04-17-2014, 10:59 AM   #5
Oso954's Avatar
Most mudrings are for 4x4 boxes, not 2 gangs. Might have to drill some holes.
But how about a 30 cu in single gang.
http://www.homedepot.com/p/Carlon-1-...-30R/202664447
Old 04-17-2014, 01:06 PM   #6
Rewards Points: 332
You can even get a single gang mud ring for plastic boxes:
sgip2000 is offline   Reply With Quote
Old 04-17-2014, 05:57 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You should have just used a 4" sq. box with a single gang mud ring...
Old 04-17-2014, 06:52 PM   #8
Rewards Points: 113
ooops! Forgot important fact. I'm trying to use an old work type box without having to open up a much larger hole. Because of the age of the paint, I'd probably have to paint the entire room.
Thanks for all the help and comments. Now I also know that the strange looking cover is called a "mud ring". Yes, I had checked the two sources as posted, but no luck there.
I appreciate all.
Old 04-17-2014, 06:53 PM   #9
E2 Electrician
I appreciate all.
Open up the back side of the room.
