Surging Window AC - Outlet Or Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2018, 06:19 AM   #1
Rewards Points: 136
Surging Window AC - Outlet or Wiring?
I’ve got an old house with knob and tube wiring. This summer I plugged a 5,000 BTU window AC in my bedroom and ran it. It’s plugged directly into the wall. No problem until 2 weeks ago.
I’d turn it on, and it would “surge”, as in it sounded like it wasn’t getting consistent power. It would run, then sound like it’s lagging and struggling for power - similar to a car’s RPMs bouncing around vs. being at a stable operating speed.
It’s not the unit itself, I ran an extension cord to a different outlet and it was perfect. This leads me to believe it’s something bigger.
Normally I’d think maybe the outlet needs help, but I’m wondering if symptoms like I’ve described are common in knob and tube homes where I should take extra precaution?
WalkThisWhey is offline   Reply With Quote
Old 09-18-2018, 07:32 AM   #2
Re: Surging Window AC - Outlet or Wiring?
What else is on the circuit that you normally plug the AC into? Another large load or several smaller loads will draw near or over the maximum that the circuit can handle.
A loose connection in the circuit could cause the same issue.
daveb1 is online now   Reply With Quote
Old 09-18-2018, 07:36 AM   #3
retired framer
Rewards Points: 12,842
And that loose connection can be hidden in a wall with out a box.
Old 09-18-2018, 08:13 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,632
Knob and tube wiring does not loop through receptacles like modern wiring. There is usually one main trunk with spurs off it to the receptacles and lights etc. The connections are all soldered. I doubt it is a loose connection on K&T unless someone has been messing with it.
Wiring help - 3 switches + Outlet 62caster Electrical 12 09-08-2016 12:50 PM
Simple Extend an Outlet Wiring Question Curmudgeon10 Electrical 15 03-05-2015 01:21 PM
Help with a Window Removal/Install anthony232 Windows and Doors 12 09-18-2013 04:39 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet Wiring Question (Please Help!) joshg3p0 Electrical 34 02-05-2010 01:40 PM
