Surge Suppressor Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2014, 05:06 PM   #1
Rewards Points: 16
Surge Suppressor question
I'm installing an outlet behind my wall mounted tv and was going to put in one of those outlets with the surge suppressor built in. I then noticed that my tv has the two prong double insulated style cord and started wondering whether a surge suppressor would work with this type of cord? Should I just put in a regular outlet?
frylock11 is offline   Reply With Quote
Old 08-17-2014, 05:08 PM   #2
Rewards Points: 774
It will still minimize any surges on the line, regardless ot the load being served.
I would condiser a SPD (Surge Protective Device) at the main service as well.
Know A Little is offline   Reply With Quote
Old 08-17-2014, 11:45 PM   #3
Rewards Points: 6,652
Actually it would be a waste with a polarized plug.
Old 08-18-2014, 04:56 AM   #4
Rewards Points: 774
So a surge on the ungrounded conductor or neutral (grounded conductor) is of no concern?
Old 08-18-2014, 05:57 AM   #5
dmxtothemax's Avatar
Rewards Points: 7,852
Provided the power strip has a ground
The spike filter will work
Even.if the tv does not have a mains ground.
Ps the tv could get a ground from the antenna system.
dmxtothemax is online now   Reply With Quote
Old 08-18-2014, 06:25 AM   #6
Rewards Points: 1,005
a transient surge in the voltage supply is goint to be transmitted through the power supply conductors - no matter if they are insulated, polarized, or if there is a three prong ground in use.
a surge suppressor is designed to absorb or re-route the voltage spike so it will not damage the load device (tv). most electronic devices do have a mov just inside the cabinet which will also help in removing the spike.
a decent lighning strike can take out almost every electrical device in a house.
TimPa is offline   Reply With Quote
Old 08-18-2014, 05:17 PM   #7
Rewards Points: 774
I have completed quite a few lighning investigations and one thing I have learned, with lighting any possible level of damage is possible. We have one cell site that we have replaced all the equipment several times. One time the tower took a hit, fried everything in the site, everything in the 7-11 200' away, and a large quanity of Comcast equipment in an adjacent facility. In the cell site it blew the SPD off the wall.
SPD's are a worthy investment, but depending on the magnitude and duration of the stroke will depned on the amount of damage.
Old 08-18-2014, 05:41 PM   #8
Whilst it is true that for a large or sustained lightning strike
Ain't much gunna help, lightning will do what it wants.
But for smaller spikes and strikes they can help,
So there not a total waste.
But we have really gone off topic
The main question was weather there needs to be a ground on the tv
for the spike filter to work ?
The answer is no !
But there needs to be a ground on the power strip.
The Following User Says Thank You to dmxtothemax For This Useful Post:
Know A Little (08-18-2014)
Whole house surge protector - questions Theuser005 Electrical 2 09-24-2012 09:52 AM
power surge with 120v relay astetson Electrical 8 01-16-2012 10:46 PM
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 08:00 AM
Getting a 200Amp Square D OQ Panel. What about surge protector? mudworm Electrical 3 10-27-2011 02:29 PM
New place, no ground in room, expensive computer pinkmanta Electrical 27 10-24-2011 01:16 PM
