Surge Protection + Master OFF--Protected? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By RAL238
Old 02-06-2019, 11:48 AM   #1
Rewards Points: 8
hello,
Ive been looking around online for a way to turn ON and OFF simultaneously my music studio gear, all with one ON/OFF switch...... as opposed to turning off/on each piece of gear (convenience).
So, all these devices are plugged into a surge protector which has a Master ON/OFF but..... if I turn the surge master switch protector OFF, then the gear is not protected by the surge protector?
-Powered monitor speakers
-Sound interface
-Guitar pedal rack
-Headphone monitor
-Laptop
Here is the surge protector I have:
https://www.panamax.com/product/surg...or-8-av-SP8-AV
Ideal scenario would be to TURN OFF/ON all gear with one master switch and have it still be protected by surge protector (and this would also help with vampire energy consumption)"
Thanks in advance for your input.
Seb
Reflex is offline   Reply With Quote
Old 02-06-2019, 11:58 AM   #2
Rewards Points: 1,890
Re: Surge Protection + Master OFF--Protected?
It depends on how the surge protector is wired internally as to whether there will still be any surge protection when the master switch is off. It's likely that the switch only disconnects the hot wire and leaves all the surge components connected to the incoming line. In that case, it still provides protection, even though the equipment is not receiving power.
If you are really worried, install a surge protector receptacle that you then plug the power strip into.
https://www.amazon.com/dp/B0006I33Y6
Or, even better, install a whole house surge protector at your breaker panel.
https://www.amazon.com/dp/B01AQAKRSS
FrodoOne likes this.
RAL238 is online now   Reply With Quote
Old 02-06-2019, 12:01 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,014
What makes you think it is not protected when turned off? I think it probably still is. The neutral and ground will still be connected and the protection will be effective to short any spikes on the off hot to ground.
edit:
I like surge receptacle suggestion.
Old 02-06-2019, 07:25 PM   #4
Rewards Points: 8
I called maker of my surge and they said in OFF it will be ok.
Thank you
Old 02-07-2019, 03:09 AM   #5
Rewards Points: 2,896
Yes, that would be better.
It would cost more to install that - or a similar competing product - but what is the cost of replacing your "music" equipment and other equipment in your dwelling?
FrodoOne is offline   Reply With Quote
Surge protection hidden 1 Electrical 2 01-12-2019 01:45 PM
Surge protection, HVAC whelmed HVAC 10 06-15-2012 09:13 PM
How does grounding work? scyarch Electrical 44 06-12-2012 04:59 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Surge Protection Primer fw2007 Electrical 3 04-09-2009 10:47 AM
