Surge Arrester Install - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2009, 09:30 AM   #1
I am installing a surge arrester in my home. I understand that the white wire connects to the grounding bar and one of the black wires to the main breaker. Where does the 2nd black wire connect?
Alpercata12 is offline   Reply With Quote
Old 10-28-2009, 09:39 AM   #2
Im certain that you do not connect the lines directly to the main breaker, most surge arrestors have you connect the white to the ground bar, and the two blacks to two different "legs" in the panel. Like the two poles of a double pole breaker, or two single pole breakers.
This can be easily accomplished with breakers that have special terminals that accept two wires. Like square d QO breakers.
What is the model of the surge arrestor you are installing?
What type of breaker panel do you have?
rgsgww is offline   Reply With Quote
Old 10-28-2009, 10:38 AM   #3
rgsgww, Thanks for your response. The panel is a Siemens. The arrester is Square D Model SDSA1175
Old 10-28-2009, 06:12 PM   #4
What type of breakers inside? Could you provide a picture of the breakers near the top of the panel?
The way they install that surge arrestor, is by taking those two hots and putting them under each terminal of two breakers side-by-side
like a double pole breaker or two single poles.
Some breaker terminals allow two wires under them, Im not sure if yours can yet.
Old 10-28-2009, 06:25 PM   #5
300zx's Avatar
Post
Double Posts Instructions Again http://ecatalog.squared.com/pubs/Ele...8291-0014D.pdf
300zx is offline   Reply With Quote
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
how difficult to install reverse osmosis filter grgryl Plumbing 3 02-07-2009 10:04 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 09:05 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Point of Entry Surge Suppression Question eltrigo Electrical 1 06-02-2005 06:14 PM
