Surface Mount Garage Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2018, 01:39 PM   #1
Rewards Points: 632
I'm replacing the garage panel and ran into a problem. The spacing between this stud is only 14.5 and the new panel won't fit.
Instead of recessed mounting my next option is to surface mount it. Is it ok to do this?
dannieboiz is offline   Reply With Quote
Old 05-23-2018, 03:18 PM   #2
Licensed electrician
Rewards Points: 3,592
Re: Surface mount garage panel?
Many panels are 14.25 inches wide to fit between studs. Surface mount should not be an issue.
Old 05-23-2018, 10:22 PM   #3
Rewards Points: 632
thanks for the quick response. Unfortunately, whoever installed this ran wires along the side of the studs taking up that valuable 1/4". Panel is 14.75, stud opening is exaclty 14.5.
7 hours later, the panel was surface mounted and power is back to the house. It's more work than it appears. Not really plug and play.
Garage + Main House Panel Sequence Question jb9 Electrical 15 09-15-2017 06:50 PM
New 20A circuit in finished garage - surface mount or fish romex? Osboy Electrical 9 11-13-2014 06:30 AM
How to Repair Ripped and Peeling Surface Layer of Wooden Garage Door Panel? Kronor Carpentry 9 07-04-2014 06:43 PM
Sub Panel to Attached Garage marly Electrical 4 06-02-2011 12:34 AM
Attached Garage, No sub panel, seperate grounding rod danocars Electrical 6 03-15-2010 05:27 PM
