Supply Cable To Panel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-21-2010, 08:59 PM   #31
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by forresth View Post
you can go down in size for a ground, so even 12 gauge would be fine.
that is no longer a valid statement.
15 amp circuit requires at least a #14 cu
20 amp- #12
30 amp- #10
40 amp-#10
60 amp- #10
100 amp- #8
200 amp- #6
as well, if the current carrying conductor is increased in size (such as to counter voltage drop) the EGC must also be upsized a like amount.
Old 06-27-2010, 06:06 PM   #32
Rewards Points: 85
Well, finally put the last breaker in the panel. Thursday night, POCO didn't arive until 11:00 pm which meant I had to stay up all night to do the work. Slept an hour and then back to it. Never finished in time for inspection, but inspector offered to inspect service cable/ground connections in order to get power back to the house! Awesome guy! Since then I've been working at completing connections in the panel. All I need to do now is fasten the cables and label up the panel. Thanks for all of your help! I will post pics once complete.
Old College Try is offline   Reply With Quote
Old 06-27-2010, 10:22 PM   #33
" Euro " electrician
frenchelectrican's Avatar
That cool and Merci for letting us know what going on and S'il vous plaît { Please } show us the photo here.
Merci.
Marc
Old 07-03-2010, 10:11 AM   #34
Rewards Points: 85
Pictures of new panel
So I finally got around to snapping a couple of pics. Not a perfect job, but enough to get compliments from my inspector. No more supply cable sweeping in from the side at least. I'm satisfied. Thanks for all your help.
Supply Cable to Panel-new-panel.jpg   Supply Cable to Panel-new-panel-open.jpg
Old 07-03-2010, 11:25 AM   #35
Looks good
Subpanel supply cable and other issues.. Katzenjammer Electrical 9 02-19-2010 09:26 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
100A Fuse Panel Replacement Charlie1101 Electrical 4 07-25-2009 02:22 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 12:20 PM
