Sump Pump Monitor ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 11:17 AM   #16
Red Squirrel makes a good point and www.basepump.com also carries a piggyback system with two electric sump pumps, one above the other, so when the water levels are normal, the lower pump takes care of it, but when the water comes up higher, the second pump kicks in. You can also install a separate alarm for when both fail as well as a backup sump pump using either water or battery power for when the power goes out or the pumps fail for whatever reason.
Pumpguy is offline   Reply With Quote
Old 02-21-2010, 01:23 AM   #17
Always learning...
fetzer85's Avatar
Rewards Points: 262
Originally Posted by antlerdancer View Post
I might be wrong,but wouldnt an audible alarm drive you crazy?
I was suggesting an audible alarm for when the pump wasn't working. I see no benefit of having a light come on when the pump comes on. Who cares when it's working? You should only be concerned when it's not working - hence the alarm.
Am I missing something?
fetzer85 is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
