<SUGGESTIONS> Need Better Garage Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 07:15 PM   #1
Rewards Points: 47
Lightbulb
<SUGGESTIONS> Need better garage lighting
Hey DIY'ers
I have your standard 20'x20' garage but with a high 12 foot ceiling. The builder installed 2 60watt lights but this just isn't sufficient.
Any suggestions about replacing these lights or something else to get it brighter inside my garage? I've attached a few photos so you can see what I have.
Thanks!
Dan
&lt;SUGGESTIONS&gt; Need better garage lighting-light-1-.jpg   &lt;SUGGESTIONS&gt; Need better garage lighting-light-2-.jpg   &lt;SUGGESTIONS&gt; Need better garage lighting-light-3-.jpg
dgates12 is offline   Reply With Quote
Old 01-22-2010, 07:23 PM   #2
Rewards Points: 1,016
Hang 6 or so 4' florescent shop fixtures - surface mount florescent fixtures - recessed can lights...
What else is on the circuit with the existing two lights? You can probably reuse that circuit, switch, etc.
Old 01-22-2010, 07:26 PM   #3
Weekend Warrior
Painting the ceiling (and walls) white would help make it brighter also.
H2O Engr is offline   Reply With Quote
Old 01-22-2010, 07:28 PM   #4
Rewards Points: 47
I was thinking about the surface mount florescent fixtures as well. Do I just disassemble the current light fixture and use the wiring, I wasn't quite sure of this part is why I posted here. I didn't want to leave some hole in the ceiling if I replace these.
Old 01-22-2010, 07:39 PM   #5
Theses are keyless fixtures theres going to be mounted to a box.U can mount your new lights over the boxes.
cdundon4va is offline   Reply With Quote
Garage Lighting??? mopowers Electrical 3 01-20-2010 02:45 PM
garage lighting handifoot Electrical 10 07-27-2009 11:11 AM
Garage subpanel installation - EMT ScottR Electrical 26 06-11-2009 12:53 PM
Lighting in my garage? wibass Electrical 5 05-20-2009 10:44 PM
lighting a garage chatterbass Electrical 13 11-19-2008 09:16 PM
