Subpanel To Outbuilding - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2010, 09:22 PM   #1
jce
subpanel to outbuilding
I'm going to be running a 240 line (for air compressor)out to my outbuilding & also need 120 for lights , power tools, etc....Only a short run about 35ft.
I am going to be installing a small panel there for seperating the lines of 240 & 120.
My question is , do I have to run 4 wires , 2 hot , 1 neutral & 1 ground.
Or can i just run the 2 hot & 1 neutral & make a new ground at the sub ?
thanks
jce is offline   Reply With Quote
Old 04-01-2010, 09:29 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 968
You need 4 wires and a ground rod at the barn.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 04-01-2010, 09:50 PM   #3
JB fan is right, You need to have your grounding conductor originate from your main service, if you can imbed your ground rod in the concrete foundation of your outbuilding
g.gauvreau is offline   Reply With Quote
Old 04-01-2010, 11:19 PM   #4
Rewards Points: 1,016
Sub panels to detached workshops and garages is a very common topic here. I suggest you do a search and review Stubbies diagrams in the stickys. Any questions remaining, fire away.
Old 04-02-2010, 07:16 PM   #5
jce
I suspected this to be the answers , my only question would be . I am thinking I read somewhere about being important to have the ground originating at the main panel & ONLY the main panel ? What is the necessity of another ground rod ?
thanks
Old 04-02-2010, 10:53 PM   #6
Rewards Points: 6,652
thanks
To ground the building because when you run service from one building to the other, you "Float" the Earth Ground between them. The 4-wire run if wanting 240, is 2 Hots, a Neutral, and Common Ground. Now, if you use Metallic Conduit between buildings, then you remove the floating ground in theory.
Grounding a Subpanel Craigman Electrical 25 12-07-2009 07:25 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
Subpanel installation in outbuilding fls Electrical 19 03-16-2008 02:19 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
