Subpanel Neutral Bar Separation - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 09:45 AM   #1
I have an older QO-Square D eight circuit panel. It is being used as a subpanel and when installed was not bonded.
The neutral bar consists of a bar mounted with one screw and a second bar mounted to it by standoffs. This second bar is where the bonding screw is. I can see no way to separate these two bars for proper bonding. There is no provision for mounting this second bar.
I wish I could post a picture but I will have to work on that.
I am thinking I will have to purchase a new panel but can't understand why neutral and ground cannot be separated.
Giles is offline   Reply With Quote
Old 02-23-2010, 09:56 AM   #2
Licensed electrician
Rewards Points: 3,654
Which way is it, bonded or not? Square D uses a green head screw to bond the buss to the enclsoure.
There are also raised threaded bumps to install auxillary grounding bars.
Old 02-23-2010, 10:24 AM   #3
Jim--I have looked at the panel several times and even removed the neutral buss. There is no place to mount a bar. It is bonded, but not properly, the way I understand bonding.
This is a sub., mounted about 6" from main panel. With this setup, neutral and ground are all connected together and bonded with housing.
I plan to separate the neutral and ground and bond the ground and add a fourth wire to run to the main panel neutral from the ground.
Is this correct.
Sure wish I could post a picture!
Old 02-23-2010, 10:41 AM   #4
What is the panel model number? FWIW I don't every remember a Sq D that did not have raised bumps for a ground buss. Look for a small christmas tree symbol.
Old 02-23-2010, 11:04 AM   #5
Cat. No. QOB 8 Series L4
A stenciled number EI8H9761
While getting these numbers I noticed a raised rectangular area about 1/2"x 1/4" with an unthreaded hole. There are two, one on either side. I was looking for two mounting points and if this is the mounting point, I can thread and use the bonding screw for mounting.
Old 02-23-2010, 12:24 PM   #6
Rewards Points: 2,800
The neutral bar consists of a bar mounted with one screw and a second bar mounted to it by standoffs. This second bar is where the bonding screw is. I.
How is the second bar connected to the first bar, or is it?
I would have thought that the first bar is for grounds and is bonded to the panel by its one screw self tapped into the back of the panel, and the second bar is optionally bonded to the panel with the green screw.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
subpanel feed neutral conductor connection in main panel rtoni Electrical 4 09-17-2008 04:29 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
