Subpanel Mounting? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 08:50 PM   #16
" Euro " electrician
frenchelectrican's Avatar
not to digress, but is it OK to double tap to a main feed ( given that the main panel is full, and cannot take any more breakers) when routing a line to a 240V sub panel?
Unforeteally that is not a safe way to do it.
Merci,Marc
Old 06-07-2009, 09:06 PM   #17
Originally Posted by Speedy Petey View Post
99.999% of the time NO.
thx. how about piggy backing (2) 120V circuits into (1) single pole breaker by using a wire nut and a pigtail?( say 2-15 Amp lines into a 1-15 Amp breaker?) This way I can free-up a couple of spaces for a double pole breaker for a 240V circuit?
banyan is offline   Reply With Quote
Old 06-07-2009, 09:26 PM   #18
That you can do that however there is one nice gotca is that if that part of MWBC then the bet is off and also if both 15 amp circuit you are pigtailing is very light load circuit you can do that but it depending on it feed to so that something you may want to think about it.
Merci,Marc
Old 06-07-2009, 09:28 PM   #19
You may want to start a new thread with your issue
Many people ignore older threads or only look at the OP question
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
