Subpanel In Attic? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 02:23 PM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
I personally would not put it in the attic just because it's harder to access, but that's just me. If you can make it easier to access, or it already is, then that's less of an issue.
Old 04-06-2010, 03:33 PM   #17
Rewards Points: 866
Originally Posted by nap View Post
it not only has to be every plug but it has to be every OUTLET.
Do you know what code cycle your area is governed by? The 08 instituted a much greater coverage of AFCI's so depending what else you are doing with this panel, you may need a few more AFCI breakers.
The current version of the California Electric Code is the 2007 CEC which is based on the 2005 NEC.
Klawman is offline   Reply With Quote
Old 04-06-2010, 07:05 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the 05 NEC still required all outlets (not just receptacles) in a bedroom to be AFCI protected. Don't know how that works into California codes but that is NEC.
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Attic Subpanel Kurt1968 Electrical 1 11-23-2009 09:30 PM
Subpanel in attic Kurt1968 Electrical 15 10-30-2009 08:15 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
adding subpanel in attic -- is this feasible? jayp Electrical 8 05-22-2009 10:22 AM
