Subpanel - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 02:28 PM   #61
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
As usual Dave makes some very good points. I would agree with him to look at the whole picture down the road considering a rewire of the home as you eliminate the knob and tube. You might give us the information off the specifications cover sheet for the model # of your new 100 amp panel. It could be 20 space but by utilizing tandem single poles will increase the circuits available to more than the number of spaces.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-05-2010, 02:31 PM   #62
Inspector/Instructor
codeone's Avatar
Originally Posted by Kurt1968 View Post
Can i get a 60 amp subpanel still all i can find is 100 amp panels. So just need to add a 60 amp breaker to the main panel and wire the subpanel to that.
Kurt, Using the 100 amp sub panel fed with 60A wire with a 60 amp breaker works with all codes. As long as you dont over fuse the wiring or the panel you will be ok.
codeone is offline   Reply With Quote
Old 01-05-2010, 04:25 PM   #63
I just looked at my panel. It's 24 spaces. Only 9 of them are used. There is 7 15 amp breakers and one double 30 for the ac.
Kurt1968 is offline   Reply With Quote
Old 01-05-2010, 04:48 PM   #64
UAW SKILLED TRADES
Stubbie's Avatar
Then I would run branch circuits from that panel instead of a sub panel.
Stubbie
Old 01-05-2010, 04:59 PM   #65
Wow, no 20a breakers?
Ah - older house & wiring - makes sense
As I mentioned earlier if you renovate you will need 20a in the kitchen (2), bathroom & laundry
But you do have 15 open spaces which is plenty
So its a matter if you woudl prefer to run (3) new runs or one sub run - then the branch circuits from the sub
Old 01-05-2010, 06:00 PM   #66
Last question. I would install the 60 amp breaker in the main panel right. Then just straight power to the sub. Do i have to buy a special panel for the sub.
Old 01-05-2010, 06:09 PM   #67
Never mind figured it out. I need a main lug panel.
Old 01-05-2010, 06:25 PM   #68
UAW SKILLED TRADES
Stubbie's Avatar
If you go with the sub-panel be sure you understand how to separate the neutral and ground. It will vary depending on the manufacturer. For example you may have to purchase a grounding bar to add to the panel if all it comes with stock is one neutral bar. Be sure any grounding bar you buy is the one for the panel you purchase and not any ole ground bar. There will be pre-swaged holes in the panel back plate that accepts the ground bar.
Stubbie
Grounding a Subpanel Craigman Electrical 25 12-07-2009 07:25 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
