Sub Panels And Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 01:53 PM   #1
sub panels and conduit
I have a GE load center that would like to use for subpanel. couple questions:
1) is there a limitation to the numbers of conduits and size going into the panel? looking a one stubbie going into it for feed and then 3 conduits from 1 inch to 1.5 inches going in from the bottom.
2) for convenience and lay out, I would like stubbie going in from the side but there is no punch out on the side. Is side feed allowable and what is the best way to put a 1.25 inch hole in the panel for the feed? there is a side feed punch out on the panel I am accessing feed .
3) as this is an outside panel, what is the minimum from the ground that it should be?
4) is there a convenient and allowable way to have two conduits "meet" underground and then the conductors run out of this junction into one larger conduit? (thinking 1 12G and 1 6G joining to go into one 1.25 or 1.5 inch conduit for rest of run (about 10 feet) for convenience and ease.
Thanks in advance for advice.
MeanGene is offline   Reply With Quote
Old 10-31-2010, 03:28 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if they fit, they are fine.
what are you running in those conduits?
yes and a proper sized hole saw or a proper sized punch. Be mindful though. Some equipment has markings of how far up the side you can put a hole. You should also use seal washers.
not in the water. Unless you are beside a body of water, there is no lower limit, only an upper limit. Common sense should guide you though with the lower limit.
nope, not underground. It would require a junction box or hand hole. It must be accessible at the surface.
Conduit Fill and routing? Roaddoggie Electrical 8 10-25-2009 12:23 PM
Question on Code w/regards to holes in Meter Bases or Panels etc. tsenator Electrical 10 10-22-2009 10:37 AM
320a Meter: Two 200a Panels? Roaddoggie Electrical 22 09-17-2009 11:13 AM
Cutler Hammer Retrofit Panels KeithM62948 Electrical 13 08-02-2009 11:39 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
