Sub Panel Under Kitchen Sink - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 04:27 PM   #1
Rewards Points: 455
Sub Panel under Kitchen Sink
Can I put a little 60amp 6 space panel under the kitchen sink area? If so, I have a plan...
Cletis is offline   Reply With Quote
The Following User Says Thank You to Cletis For This Useful Post:
ritelec (01-08-2015)
Old 01-08-2015, 04:37 PM   #2
Rewards Points: 1,832
Ibtl...
Jump-start is offline   Reply With Quote
Old 01-08-2015, 05:37 PM   #3
Licensed electrician
Rewards Points: 3,836
Trolling, trolling , trolling, keep those posters trolling .
Sung to the tune of Rawhide.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (01-08-2015), jbfan (01-08-2015)
Old 01-08-2015, 05:49 PM   #4
Rewards Points: 1,192
Get out your 2014 codebook, look in the index under sub-panels, accecptable locations. I won't do your homework.
bobelectric is offline   Reply With Quote
Old 01-08-2015, 06:01 PM   #5
Rewards Points: 3,362
Can you put your head in a alligators mouth?
Same thing. Not much of an idea....
ktkelly is online now   Reply With Quote
The Following User Says Thank You to ktkelly For This Useful Post:
Old 01-08-2015, 06:03 PM   #6
PoleCat's Avatar
Rewards Points: 1,658
Cletis again? Try a toaster in the tub first.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 01-08-2015, 06:52 PM   #7
Should have plenty of space and it won't clutter up the counter. Just don't wire it.
Old 01-08-2015, 07:28 PM   #8
Rewards Points: 3,396
I actually like the question... does the 6" obstruction under the panel or does the 30" and 3' requirements also pertain to the sub panel?
You could probably put a 2 circuit sub there, you can put switches and receptacles a a boat load of other things....
Can a panel be installed under a sink?
Why not?
ritelec is offline   Reply With Quote
Old 01-08-2015, 07:29 PM   #9
Super Moderator
joed's Avatar
Rewards Points: 31,920
Why is this guy Cletis still not banned from here?
The Following 2 Users Say Thank You to joed For This Useful Post:
Jim Port (01-08-2015), JKeefe (01-09-2015)
Old 01-08-2015, 07:37 PM   #10
I have no idea but this exact same posting has gotten him booted from other forums.
Old 01-08-2015, 07:39 PM   #11
Rewards Points: 455
I thought there is no such thing as a stupid question ?
Old 01-08-2015, 07:40 PM   #12
But you know the answer, that's the thing. You've asked this before on ET.
Old 01-08-2015, 07:42 PM   #13
Why should he get band?
It's an honest question..
Can you just answer it?
Old 01-08-2015, 07:45 PM   #14
Master Electrician
Rewards Points: 5,374
Can you show me where " sub-panels" are listed in ANY code book?
brric is online now   Reply With Quote
Old 01-08-2015, 07:47 PM   #15
Master Electrician
Why not?
Not too much headroom for one.
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 11:01 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
