Sub Panel For New Addition - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2017, 12:44 PM   #1
Rewards Points: 96
Sub panel for new addition
Hello everyone,
I just had a new addition done for the house. It is a three story addition attached directly to the left of the house. They had put in a grounding rod and a long green ground cable and stated that this was for the electrician. Well guess what.. thats me...
I want to hook up a sub panel for the new addition. Where does this green wire go to? Does it get wired to the main or the subpanel?
Thanks in advance
mleelun is offline   Reply With Quote
Old 07-07-2017, 12:49 PM   #2
Rewards Points: 637
Re: Sub panel for new addition
You don't need a separate grounding system for the addition, so I assume it's for the main. But how does it already not have one? Is this an old building?
csab_ is offline   Reply With Quote
Old 07-07-2017, 10:12 PM   #3
Rewards Points: 96
Not terribly old... built in 1977 i think...
the main already has a grounding system. so i dont know what to do with this other wire...
Old 07-08-2017, 08:19 AM   #4
Master Electrician
Rewards Points: 5,082
If it is a new Ufer from the addition footings terminate it in the main panel.
brric is offline   Reply With Quote
Old 07-08-2017, 10:27 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,390
Kinda strange to have the builder/non-electrician install the ground rod and GEC wire.
Maybe it's some local convention on new build... maybe difficult ground driving the ground rod and the rod was put in at foundation time and the wire attached to locate it... and the foundation guys did not realize it wasn't required for an addition/subpanel.....????? ....just guessing.
MTN REMODEL LLC is offline   Reply With Quote
panel upgrade options for new HVAC installation buyabook Electrical 12 09-14-2015 10:39 PM
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
Sub Panel over 10g-2 Help Needed hamblinh Electrical 30 01-18-2013 07:46 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
