Sub Panel Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 09:52 PM   #1
sub panel hook up
I have a SD QO 200 amp main panel in my house and I want to put in a 100 amp SD QO sub panel right next to my main box . I have # 2 aluminum SE cable 3 conductor and # 4 copper ground wire. Can I run the ground wire to the grounding rod 3' away instead of trying to fit in the old panel?
dano2 is offline   Reply With Quote
Old 05-07-2010, 09:59 PM   #2
Inspector/Instructor
codeone's Avatar
NO you need to run SER cable to your sub panel, which has 2 hots a neutral and a ground in the same cable. You also need to seperate your grounds and neutrals in the sub panel. Which code are you under in your area? 2005? 2008? This needs. to be known to give you the wire size
codeone is offline   Reply With Quote
Old 05-07-2010, 10:21 PM   #3
the code year is 2005, so I need a 4 conductor from the main panel to the sub panel and a grounding rod for the sub panel and no bonding screw
Old 05-07-2010, 10:30 PM   #4
codeone's Avatar
Unless your local codes require the ground rod to the sub panel, the NEC does not require the sub-panel to be tied to the ground rod. The reason I asked about the 2005 or 2008 code is the 2008 requires SE or SER cable to be rated out of the 60 degree column which would cause the ampacity of the wire to be less. #2 alumn would be only good for 75A. instead of 90A.
Also correct on no bonding screw, grounds and neutrals have to be seperate in a sub panel.
Old 05-07-2010, 10:43 PM   #5
So aluminum SE cable is 2 hots and a bare neutral . SER cable is 2 hots, neutral, and a ground? Thanks for all the info its been 10 years since I did a panel.
Old 05-08-2010, 07:16 AM   #6
codeone's Avatar
Yep. and your welcome
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
240v sub panel hook up with no neutral ut74 Electrical 7 03-07-2008 07:30 PM
100 amp sub panel hook up? ponch37300 Electrical 24 11-30-2007 11:47 PM
