Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 02:24 PM   #1
Rewards Points: 193
Sub panel
Hello all – I am in the middle of a kitchen remodel and am starting on the wiring. We will be replacing our electric stove with an all gas cook-top/oven. Here’s what I want to do:
I want to take the 40 amp circuit that was feeding the old stove and bring it into a sub panel and then bring two 20 amp circuits off of that. The 40 amp circuit in the main panel is double pole and the wire has two black (hot) and one silver wire (ground). An electrician friend said I can connect one black to a hot bus bar and jump to the other. The second black would go to neutral and the silver would go to ground. This would create a single pole only panel. Sound right? Thanks
Jack E is offline   Reply With Quote
Old 04-14-2010, 02:28 PM   #2
Sub panels need a 4 wire feed usually...but you want only 120v
What size is the wire ? If #8 I do no think the black hot can be remarked white
Where are you located
Old 04-14-2010, 03:00 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,998
Can't do it. You need a white wire for neutral. Wire under #6 is not permittd to remarked white.
Old 04-14-2010, 04:15 PM   #4
Rewards Points: 193
Thanks for the replies. I live in Oregon. The house was build in 1978. I think the wire on the 40 amp circut is 8 guage I have to varify. If it is 10 guage would it be possible without running additional wire? Thanks
Old 04-14-2010, 05:47 PM   #5
What type of wire are we talking about? Wire in pipe or a cable?
Shrute is offline   Reply With Quote
Old 04-14-2010, 06:33 PM   #6
Master Electrician
Rewards Points: 5,082
I have to wonder why you would install a panel for two 20 amp circuits. Is there an issue with pulling new circuits?
brric is offline   Reply With Quote
Old 04-14-2010, 07:21 PM   #7
You do realize you need to keep 30" clear left to right & 36" clear in front of this panel ? Plus area above?
Old 04-14-2010, 07:48 PM   #8
Super Moderator
joed's Avatar
It always amazes me that people want to install a gas stove and use the old power wire. You need to get a gas line there. Pull a new circuit at the same time. If you can get a gas pipe there how hard can it be to get a cable there.
The Following User Says Thank You to joed For This Useful Post:
junkcollector (04-14-2010)
Old 04-14-2010, 08:33 PM   #9
Having a new circuit ran by an EC could cost $200-300 in addition to the cost of having the gas pipe installed. So it makes sense for people to inquire about rigging the existing wiring for their new purpose at a much lower cost.
Old 04-14-2010, 08:41 PM   #10
Master Electrician
Makes a lot of sense. Especially when they have know clue what they are doing.
Old 04-14-2010, 09:38 PM   #11
Super Moderator
joed's Avatar
'Rigging' is the key word in that statement.
Old 04-14-2010, 10:18 PM   #12
Rewards Points: 193
Thanks to all for the input. Scuba Dave your point is well taken regarding the surrounding dimensions for the panel; my initial thought for placement would be too small. My thought on the sub panel was to keep the existing wire in place in case future owners (or us) wanted an electric stove. I have one slot left in my panel and don't necessarily want to install a new panel as the one I have is only a few months old (I needed to replace a fed pacific.) I'm reading a strong recommendation from most of you to re-think my plan. Thanks again for the input.
Old 04-14-2010, 10:57 PM   #13
If anything I'd put a sub panel in the basement if you have one
Use the 40a breaker to power it - use a small 100a panel
Just run some new wire, then you have a 40a 240v sub & can run several 120v circuits off of it
That way you have more room for circuits & the old wire can stay where it is in case its ever needed
Old 04-15-2010, 07:03 AM   #14
Exactly, that's why they come and ask. It seems sensible to ask a simple question that might save them hundreds of dollars, I do it all the time with things that I am not familiar with.
Old 04-15-2010, 10:11 AM   #15
Rewards Points: 193
I looked at my space again and realized I have a spot in the basement that should work well for a sub panel. It has the required space and the exisiting 8-2 wire will easily reach. If I proceed with the project I will check with my county code people about changing one of the hots to a neutral. It would be pretty easy to pull new wire from the main panel however...I'll have to weigh the pros and cons. Thanks again.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
