Sub Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2013, 09:18 AM   #1
Rewards Points: 113
sub meter
My wife has a Kiln in the garage that runs off of 240. I would like to see if there is an inexpensive way to determine how much power it uses per firing. Is there an inexpensive sub meter that we could use? I have seen the "kill-a-watt" meters but they only work with 120volts and I don't think they keep track of total usage. At peak it uses 40 amps, but it cycles on and off a lot. Trying to figure out the cost of each firing.
rjgogo is offline   Reply With Quote
Old 10-01-2013, 11:14 AM   #2
Rewards Points: 768
How about something like this?
http://www.theenergydetective.com/ted5000products
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
kwilcox (10-03-2013)
Old 10-01-2013, 11:38 AM   #3
Rewards Points: 113
Thanks, that is interesting but I only need to measure one receptacle and at $240 it is kind of pricey. The receptacle comes off a sub panel in the garage, and I would have no easy way to get the network connection that is required as the garage is detached from the house and a long way from my router. I also don't need real time data, just need to know how much an average firing costs, I can't do it via math because it goes on and off a lot.
Old 10-01-2013, 12:22 PM   #4
Rewards Points: 51
Found a meter on Amazon for $120. Would the manufacturer not have this information? I guess at the basic level, you could get a beginning meter reading from your service socket, run the kiln and get an end reading. Then just convert your kilowatt-hours backwards. Of course do this During a period of no other activity such as overnight or early morning(if you can live without AC for a few hours)?
RunningSparky is offline   Reply With Quote
Old 10-01-2013, 04:06 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 3,666
The kiln uses enough power that you can probably just read it off your home's main meter. The day after the firing, read the home's usage over the same time span and deduct that amount. If you are not running electric heat or AC a lot at the same time as the kiln, then the kiln's usage will totally overwhelm the rest of the house's. If you really want a more accurate calculation, you could connect an hour meter across the heating element terminals, like this one:
http://www.amazon.com/Intermatic-FWZ.../dp/B005IHXOYO
The hour meter will record the actual time the elements are really on, and multiplying by the kiln's kW consumption (240V times the number of amps) and your utility rate will give you the cost.
If the kiln draws 40A, that's 9.6kW. At an average rate of $0.12/kWh, that is about $1.10 per hour of actual operation. The first several hours of a firing are at reduced power which gradually increases. So if the firing takes 8 hours from start to cone-melt, then that might be the equivalent of 6-7 hours at full power, or about $7-8.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-01-2013, 04:19 PM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Sounds to me you better leave wifey's kiln alone, and tell her it doesn't matter how much it costs, as long as she loves doing it.
wirenut1110 is offline   Reply With Quote
The Following 3 Users Say Thank You to wirenut1110 For This Useful Post:
dabeast (10-01-2013), Philly Master (10-01-2013), stickboy1375 (10-02-2013)
Old 10-01-2013, 08:02 PM   #7
Rewards Points: 548
go to EBAY & look under watthour meters.get one that is called an "A" base type , they usually start around $10. with these you don't need a socket, just put the wires under the proper screws, & your ready to go.
circuitman is offline   Reply With Quote
Old 10-02-2013, 02:54 PM   #8
Rewards Points: 113
Thanks for the replies, the Kiln can run for up to 12 hours and we have an electric hot water heater that could impact the results. The hour meter idea seems good, I just tap into the lines going to the coils and that is it?
The used meter may be possible as well, I could hard wire to the panel and then put my outlet under it.
And finally, the reason for metering is that it is a small business and the true cost needs to be determined so that we can enter it as an expense.
We only have a 200 amp service and with this at 40 amps I may have to be careful when it is running.
Old 10-02-2013, 05:15 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
yeah, it will never be a problem.... i can guarantee you that.
Old 10-02-2013, 06:36 PM   #10
An old Tradesmen
Rewards Points: 9,242
Electric water heater(4.5KW heating element), and a 40 amp kiln. No problem on a 200 amp service.
Old 10-02-2013, 07:03 PM   #11
E2 Electrician
It will be fine on a 100 amp service....
Old 10-02-2013, 07:21 PM   #12
Rewards Points: 548
the sub meter could handle both of these also.if your intrested i have one i would sale for $10+shipping .just let me know.
Sizing of Water Meter Perry401 Plumbing 6 05-23-2013 05:38 AM
meter & main service panel upgrade from 100amp to 200amp CapeCod153 Electrical 2 03-26-2013 07:23 AM
Meter Main problem. right-sided meter? acerunner Electrical 6 07-23-2011 12:41 PM
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 09:51 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
