Stupid Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 09:38 PM   #1
Bigmike33's Avatar
Stupid question
Am I able to add 2 recessed lights from the middle of the lighting run or do I need to pick up the new lights from the last light on the run? I'm pretty sure I know the answer but need confirmation.
For example there are 4 existing lights lets say the 4th light is on the end of the run. Can I tap off the 2nd light and run 2 more lights or do I have to pick it up off the 4th one (the end)
Thanks guys, I promise most of my questions arent this bad.
Bigmike33 is offline   Reply With Quote
Old 06-25-2010, 09:48 PM   #2
I=E/R
a7ecorsair's Avatar
Are the existing lights on a switch circuit? If so, are all four lights controlled by the same switch?
a7ecorsair is offline   Reply With Quote
Old 06-25-2010, 10:25 PM   #3
Bigmike33's Avatar
Yes all 4 lights are on the same switch and I am trying to add 2 more
Old 06-25-2010, 11:16 PM   #4
Rewards Points: 85
You should be able to tap in on any light if they'll all be on the same switch. Just be sure to use the same wire size (or at least not smaller) as used on the existing lights.
Old College Try is offline   Reply With Quote
Old 06-25-2010, 11:34 PM   #5
Bigmike33's Avatar
Good deal . I appreciate it. I did in fact use the same size wire than the existing.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 07:55 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Water won't drain down in lawn. Help! kbrena Landscaping & Lawn Care 17 07-17-2008 12:43 AM
maybe stupid question: marker for concrete amakarevic Building & Construction 2 06-30-2008 05:17 PM
