Stumped, 4-way Controlling 1/2 Of Outlets In Room - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 04:01 PM   #1
msk
stumped, 4-way controlling 1/2 of outlets in room
So my wife talked me into replacing every outlet/switch out in the house. i've been learning as i go, but somehow got frustrated at one point and have some wires switched. any help would be appreciated. i have a 4 way switch, with a 3-way on either side, which control one half of the outlets in the room, the other half are on constantly. i'd replaced the outlets earlier in the process. i've been reading up on wiring a 4way, but it doesnt seem to apply.
at one 3-way, i've got a hot black, a white which reads 54volts, and a red, all from one cable.
at the other, ive got a hot red, and another red and white
between them, at the 4 way ive got a white and red coming in from each 3way?
despite my effort to keep wires labeled as i switched, i messed something up, ive tried every configuration i didn't think would burn the house down, all outlets work all the time. the switches are lighted, and at different points one or another would light up about halfway.
can someone tell me what i've done? is it possible i miswired something in one of the outlets thats messing me up? why do i have a hot on either end? everything i've read indicates only one, with the other side's common continuing to the fixture/receptacle.
msk is offline   Reply With Quote
Old 08-01-2010, 07:16 PM   #2
Rewards Points: 2,800
at the other, ive got a hot red, and another red and white.
Is that all you find in each 3 way switch box?
When you measured 54 volts at a white wire, what was the other test lead of the meter touched or clipped to?
Are any outlets supposed to be controlled by the switch?
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 08-01-2010, 07:47 PM   #3
msk
no, all 3 switches are part of multiple switch boxes, but i was careful to do them one at a time so as not to confuse them.
the other end was on ground
yes, half of each (6-7) outlets had been controlled by the 3 switches.
in doing some further thinking, i disconnected all switches completely, and had hot on black on one end, and hot on red on the other. i was somehow getting the 54 once i had things hooked up, and it was switching sides depending on the orientation of the switch. the other side would have full voltage.
each 3way also has a red and white, which lead to the 4 way switch. since i didn't have a long enough jumper, i tied these together at the 3 way and tested continuity at the 4way, and they made a loop. so these are my jumpers, and i can hook one side to the bottom, and one to the top right?
thanks.
Old 08-01-2010, 08:17 PM   #4
dSilanskas's Avatar
The plugs that the switches control you have to break the copper tab that connects the copper screws together aka hot side. It sounds like you didn't break the tab and you have constat power on one end when it's supposed to be the switched end. Break that tab on the outlets and you will fix your issue.
dSilanskas is offline   Reply With Quote
Old 08-01-2010, 08:28 PM   #5
msk
I didn't. makes sense. back to work. thank you
Old 08-01-2010, 08:30 PM   #6
dSilanskas's Avatar
Welcome. Let us know how you make out
Old 08-01-2010, 08:40 PM   #7
did you break all the tabs on the outlets since they are half hots
jer24er is offline   Reply With Quote
Old 08-01-2010, 09:52 PM   #8
msk
all set
Thanks for help all. Broke out the tabs and after a little trial and error got all switches functioning properly. Thanks again.
My scrapbooking room gma2rjc Project Showcase 58 08-31-2016 01:13 AM
Questions for experts. Tech08 HVAC 9 01-25-2009 12:47 PM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 10:08 AM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
