Stripping UF Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2015, 01:56 PM   #1
Rewards Points: 3,130
Stripping UF Cable
I've only had to do it a couple of times, and found the process quite tedious. Now, I need to do it again for a solar panel project I'm in the middle of. Any tips/tricks/tools out there to make the process easier??
Old 11-16-2015, 03:08 PM   #2
Rewards Points: 2,005
Try a Romex stripper . Although , I am not sure it will work on UF ?
Id not , a utility knife with a new , sharp brade . Still going to be a pain .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 11-16-2015, 03:26 PM   #3
Rewards Points: 422
Stripping UF Cable
Best bet is to use diagonal cutters to snip apart the sheath at the tip and separate the conductors - then hold one of the ends and use a utility knife to cut downward and away from your hands and body.
Pharon is offline   Reply With Quote
Old 11-16-2015, 06:56 PM   #4
Thanks. I guess there's no easy way to get it done. I have a utility knife and lots of new blades, so I guess I'll just have to deal with it.
Old 11-16-2015, 08:21 PM   #5
Licensed electrician
Rewards Points: 3,766
It strips better if warm. I slide a sharp razor knife blade alongside the conductors .
Tags
stripping , uf cable
Connecting to HDTV - Quality Questions miamicuse Home Theater 45 06-24-2014 11:00 AM
Locating Service Cable from Meter to Panel the_titan Electrical 5 02-28-2014 01:22 PM
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 12:35 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
