Strange Voltage Measurements - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 06:36 PM   #1
Rewards Points: 91
strange voltage measurements
I'm replacing a daisy chained outlet, and I used my meter to double check that the power is indeed off.
I'm measuring 1V and 0V AC on the feed to the outlet and the daisy chain from the outlet, respectively. So thats fine. But when I measure voltage across the hot side from the feed and the neutral from the daisy chain, or vice versa, I measure about 18V. Is this just because I'm probing a floating wire in each instance, and I'm picking up stray voltage from elsewhere, which screws up my meter?
debiasio is offline   Reply With Quote
Old 08-10-2010, 07:22 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 24,048
You are using a digital meter. The phenomenon is called phantom voltage. If you apply a load to the circuit it will likely go to zero volts.
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 09:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
Low voltage to vacuum [email protected] Electrical 2 03-04-2007 09:38 AM
