Strange Outlet/switch Issue... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 12:36 PM   #1
Strange outlet/switch issue...
I have an standard outlet that the TOP is controlled by a light switch. Last week it sparked and went dead!
I checked the power to the outlet and of course there's none to the top one so I replaced it and now there's power to both.
My problem is this...the outlet works but the switch doesn't control either outlet! What gives? I've checked the switch and there's power to it on both sides.
HELP!
es0412 is offline   Reply With Quote
Old 01-27-2010, 12:49 PM   #2
did you remove these?
06bluez is offline   Reply With Quote
Old 01-27-2010, 12:58 PM   #3
I did NOT remove the brass tabs (I don't recall actually seeing them). The outlet I replaced was there before I bought the house 3 yrs ago.
Old 01-27-2010, 01:00 PM   #4
I just looked at the one I replaced and the tabs on the RIGHT side were removed.
Old 01-27-2010, 01:01 PM   #5
well to have the top switched only, like you had before, you will need to remove the brass tab. this allows each half of the outlet to be separated and wired independently. They are on BOTH sides, but only the BRASS (hot) side should be removed by twisting with a pair of pliers.
Old 01-27-2010, 01:04 PM   #6
Interesting and thanks! I'll try that.
Old 01-27-2010, 03:43 PM   #7
Well, I tried breaking off the tab and now the top outlet isn't working at all again, just like the original issue.
Any other ideas?
Old 01-27-2010, 03:49 PM   #8
are you sure the switch is not bad?
Paelectrican is offline   Reply With Quote
Old 01-27-2010, 03:53 PM   #9
Well, after I removed the tab, I didn't have power to the top outlet again. I do have power to the switch so I assumed it was ok.
It's strange because it stopped working out of the blue.
Old 01-27-2010, 04:00 PM   #10
Ok, you have power at the switch but do you have power leaving the switch?
Old 01-27-2010, 04:17 PM   #11
I have power to the top of the switch and to the bottom of it ONLY when the switch is turned on.
Old 01-27-2010, 05:56 PM   #12
Super Moderator
joed's Avatar
Rewards Points: 23,986
Did you remove the tab on the hot(gold screw, black wire) side. If you removed the tab on the white wire side that would cause your problem.
Old 01-27-2010, 06:05 PM   #13
I removed the GOLD tab (the hot side).
Old 01-27-2010, 06:07 PM   #14
On the brass side you should now have 2 wires going to that side
One is hot all the time - for the bottom outlet
The other is the hot from the switch - only hot when the switch is on
**Please note this could be a white wire - check to see what color that wire is from the switch that is only hot when the switch is on
Old 01-27-2010, 06:15 PM   #15
Currently I have a BLACK and RED wire on the brass side and 1 WHITE wire on the silver side. This setup has not changed. Both outlets were working before I removed the tab but neither worked with the switch. I checked the switch and have power to both top & bottom screws.
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
Please expleain a Strange florescent issue beerdog Electrical 2 04-30-2009 12:47 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
