Strange Doings In A Fluorescent Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 08:09 AM   #1
Strange doings in a fluorescent fixture
I have a very perplexing phenomenon regarding a fluorescent fixture in my kitchen (2 40W tubes, rapid start).
The fixture was working fine. I took it down to try another fixture in its place, and eventually replaced the original fixture.
When I did, the tubes would not light fully. When I replaced it, the wiring was the same as when I'd removed it--white to white, black to black, ground connected.
In desperation, I did some experimenting, and wired white to black. Again the tubes would not light up fully. But I discovered that if I did not connect the ground wire, and instead touched it briefly to ground, it sparked, and the tubes became fully lit!
What is going on here? And how do I make thix fixture operate correctly, as it did before I removed it? Thanks.
Mr_allthumbs is offline   Reply With Quote
Old 09-03-2012, 08:49 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 358
Sounds like a bad ballast or bad tube(s). I know you say it was working before you took it down but it may have been getting weak. BTW, do not leave it connected the way you did as a trial.
IF this is a T12 fixture it is a good time to replace the ballast and lamps and convert to T8s.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 09-03-2012, 04:05 PM   #3
Ballast & bulbs
RJ, I *think* it was the ballast. This fixture had been in place for probably 10 years (all the while, hated by my wife). We took it down to see what kind of light a newer fixture would give. We did not like the newer fixture, so I replaced the old one, and that is when I noticed the problem.
I took it down to my workshop and experimented with it. Regardless of whether white was connected to white or black, when I connected the ground, my GFI popped. So I conclude that in removing and then replacing it, I probably knocked aside a piece of brittle insulation, which caused the problem.
As to T8s and T12s, today I replaced the old fixture (T12s) with one to my wife's liking, 2 T8 bulbs. But it provides a bit less light than the older one.
Old 09-04-2012, 05:53 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 358
The balast has internal leakage. That is why you saw the spark when you connected the ground.
I would replace the T12 with T12 if you are unhappy with the amount of light from the T8. But remember in 10 years when it needs replacement- T12 will have been phased out.
The Following User Says Thank You to rjniles For This Useful Post:
Mr_allthumbs (09-05-2012)
Old 09-05-2012, 08:12 AM   #5
Aaaah, thank you, RJ. Very clear, on-point explanation and information. My guess is that when I removed the fixture, I probably disturbed some brittle insulation.
hardwire a pre wired, plug in fluorescent fixture...? inlovewithohio Electrical 3 12-01-2010 11:10 AM
Wiring fluorescent fixture to ceiling box Richo Electrical 12 08-05-2010 06:19 PM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
Motion sensor & fluorescent fixture issue trclac Electrical 5 05-10-2010 10:42 AM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 05:51 PM
