Steam Shower 30 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 05:14 PM   #1
Steam shower 30 amp circuit
I'm about to install a steam shower which calls for a 30 amp GFCI breaker.
Items to be installed are a single pole Federal Pioneer 30 amp GFCI breaker and 10g wire.
My predicament is that the electronics module that came with the shower package has a plug-in made for a duplex receptacle. Anyone have an idea how I can rig this up to work without frying my home?
Northside Taco is offline   Reply With Quote
Old 12-02-2009, 08:41 PM   #2
Electrical Contractor
kbsparky's Avatar
Is the electronics module separate from the steam generator unit? Does it have a separate cord and plug attached?
Sounds like your unit may need more than one circuit to perform properly?
-KB
Old 12-02-2009, 08:43 PM   #3
...is this a possible solution? Permanently remove the plug-in cord and hardwire the 10g wire in it's place. Therefore a direct wire to the 30Amp GFCI breaker.
Old 12-02-2009, 08:47 PM   #4
Hi, the steam generator box actually has an s-video style cable along with a thicker shielded cord which connects to the mainbrain of the shower. The only component on this particular shower that connects to a external 30 amp current is the mainbrain.
Old 12-02-2009, 09:07 PM   #5
Thumbs down
NOOOOOO!!!! Are you kidding. A Duplex receptacle is rated for either 15 or 20 Amps. When you hook it up directly to a 30Amp. circuit you won't have any protection!!!
spark plug is offline   Reply With Quote
Old 12-02-2009, 09:26 PM   #6
That's what I gather...is there an actual option?
Old 12-02-2009, 09:37 PM   #7
Lightbulb
Without reading the actual specifics in the manual it's next to impossible. But assuming (which is risky in itself) that the control module runs on a different voltage. Either run a dedicated circuit or use a general 120v. receptacle to the module. But again. You must read the specs. (describing the voltage/s and amperage or wattage) about all the parts of the steam generator and control module before proceeding. (No matter what) Don't Drink and Drive, Ever!!!
Old 12-02-2009, 09:47 PM   #8
Specs listed as
Voltage 110V-120V
Frequency 60 Hz
Power 30W
Control circuit voltage 12V
That's about all I could find.
Old 12-02-2009, 09:56 PM   #9
Thumbs up
Specs listed as
Voltage 110V-120V
Frequency 60 Hz
Power 30W
That's for the Control panel. You (probably) have a Transformer inside the control module. My personal advice would be for you to have the entire system set up professionally by a person who does this for a living! Good Luck!
Old 12-02-2009, 10:04 PM   #10
Yes there is a transformer inside the module.
But, in the best interest of having this done in a safe manner I'll take your advice and have it done by a pro.
What is the Correct thinset for Steam Shower? Ed1234 General DIY Discussions 1 11-10-2009 09:34 PM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 08:17 PM
Steam Shower Permit jabrams General DIY Discussions 1 08-05-2009 02:15 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
