Squirrel In The Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2009, 06:56 AM   #1
Squirrel in the attic
I had a problem with squirrels getting in the attic. I fixed the vent on the end of the house to keep them out. When I was in the attic I noticed that they had chewed the insulation off of some of the wiring. Would it be be ok to use a rubberized tape and then tape over with electrical to fix the bare wires showing or do I need to replace all the places that are bare in areas. Most places are small. there are some large areas also.
Strick is offline   Reply With Quote
Old 10-17-2009, 08:59 AM   #2
My 2 cents would be to replace the damaged wire, you'll feel safer. I'd make the splices in added junction boxes.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 10-17-2009, 12:31 PM   #3
J. V.'s Avatar
Rewards Points: 520
How old is this wire? If it's old wire replace it. If it's new wire you can repair it, but I am not advising you to do that. It will be much safer if you replace.
If it worked before you worked on it. You did something wrong.
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
