Sprinkler To Buried Cable Regulation ? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2015, 11:35 AM   #1
Rewards Points: 14
Sprinkler to buried cable regulation ?
Hi
Is there any code regarding the distance from a buried 120v cable to a water line/sprinkler ?
oddball is offline   Reply With Quote
Old 09-11-2015, 11:46 AM   #2
Rewards Points: 5,348
Underground line voltage should be a lot deeper(18") then the sprinkler pipe(6-8").
Ron
B. Franklin 1759
Old 09-11-2015, 12:37 PM   #3
Rewards Points: 14
Yes, i was planning on running it 18" under the soil .
I meant more along the lines of a minimum distance it could run parallel to.
In the case of running it in rigid only 6" under it would be the same depth as the sprinklers and was there any special way the lines would need to cross
Nicked insulation on buried cable to meter mach1mark Electrical 16 10-13-2013 10:54 AM
Power cable wire nutted in return duct not in box pex006 Electrical 25 07-15-2013 11:32 AM
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 12:35 AM
Aerial Cable to Garage & Adding Sub Panel CDW59 Electrical 5 12-09-2011 06:43 AM
trenching near buried electric cable rizzo Landscaping & Lawn Care 9 04-22-2009 07:24 PM
