Splicing Wires Of An Outdoor Transformer Instead Of GFCI Plug In - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Jim Port
  • 2 Post By afjes2015
Old 05-19-2020, 09:00 PM   #1
Rewards Points: 50
Question
Splicing wires of an Outdoor Transformer instead of GFCI plug in
Hello Everyone! I am looking to install landscape lighting (Low voltage) which will have a step down transformer. Most of the ones I saw have a plug that has to be connected to a GFCI outlet.
I don't have any outlet nearby but there is a floodlight mounted on a junction box. Can I cut the transformer cord plug, thread it through a 1/2" or 3/4" inch PVC and into the box ensuring the seams are waterproofed?
Attached is the floodlight image. I was thinking of removing the screw at the bottom and threading PVC from there.
Splicing wires of an Outdoor Transformer instead of GFCI plug in-img_20180811_171845.jpg
alok_sathaye is offline   Reply With Quote
Old 05-19-2020, 09:16 PM   #2
Licensed electrician
Rewards Points: 3,842
Just add a receptacle from a new conduit fed out of the open knockout on the floodlight box.
mpoulton and alok_sathaye like this.
Old 05-19-2020, 09:21 PM   #3
Rewards Points: 1,590
Re: Splicing wires of an Outdoor Transformer instead of GFCI plug in
Nothing requires a GFCI *outlet*. GFCI devices are able to protect other outlets fed off of them. So a GFCI device in location X can protect a plain outlet at location Y, at which point Location Y is also GFCI protected. That will satisfy the requirement in the instructions.
It works best to put GFCI devices indoors so they don't get thrashed by the weather.
seharper is offline   Reply With Quote
The Following User Says Thank You to seharper For This Useful Post:
alok_sathaye (05-20-2020)
Old 05-20-2020, 06:18 AM   #4
Rewards Points: 770
If you tap into that flood light I would think then that your landscape lighting would be dependent on the fact if that flood light was on or off. Meaning the flood light would have to be on for the landscape lighting to be on and the landscape lighting would go off when you switch the flood light off.
afjes2015 is offline   Reply With Quote
The Following User Says Thank You to afjes2015 For This Useful Post:
Old 05-20-2020, 06:47 AM   #5
Rewards Points: 1,628
you cant cut plug of any transformer/appliance, it will void is UL listing
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
Old 05-20-2020, 01:12 PM   #6
Rewards Points: 50
True and I am looking at converting the floodlight to a motion sensor one. that way both could just stay on the same switch. Ideal would be to have a separate wire altogether for the LV lights and use the photocell for turning them On / Off but I don't have an easy way to pull a new wire
Old 05-22-2020, 11:20 PM   #7
Rewards Points: 50
Update: I made the necessary additions / changes and attaching the results. Ty for all the help! I changed the floodlights to motion sensor ones.
Next is to add the transformer and run the LV wires around.
Splicing wires of an Outdoor Transformer instead of GFCI plug in-img_20200522_141033.jpg   Splicing wires of an Outdoor Transformer instead of GFCI plug in-img_20200522_141044.jpg   Splicing wires of an Outdoor Transformer instead of GFCI plug in-img_20200522_141054.jpg
Tags
landscape lighting , landscape wiring , low voltage transformer
