Splice 6 Awg Between 8 Awg - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 01:56 PM   #1
splice 6 awg between 8 awg
I have a dock that has it's own sub-panel. The wire leading to the sub-panel from the house breaker box is 8 awg (3 stranded wires plus ground). When a storm broke my walkway to the dock, the wire broke and a 40' section has to be replaced. I accidently bought 6 awg wire and already ran it through 40' of conduit. The breaker at the house is 40amp. Can I splice the 6awg wire between the two 8 awg pieces? Thanks for your help.
darrenl is offline   Reply With Quote
Old 06-12-2010, 02:14 PM   #2
Yes that's fine - larger wire is OK
Splices just can't be buried
The Following User Says Thank You to Scuba_Dave For This Useful Post:
darrenl (06-12-2010)
Old 06-12-2010, 05:15 PM   #3
I=E/R
a7ecorsair's Avatar
Scuba D,
Where does it say splices can't be buried? I have splices for #6 AL that include a piece of heat shrink and the package says it can be buried and my inspector agreed.
When the power company was out to measure up for placing a ground mounted transformer, I mentioned it to him too an he says they bury heat shrink sealed splices all the time.
a7ecorsair is offline   Reply With Quote
Old 06-13-2010, 09:57 AM   #4
Rewards Points: 308
As long as the splice kit is intended and listed for direct burial, the OP can splice it and cover it with dirt. Personally I would install a hand hole and make my splice in it.
Old 06-13-2010, 10:15 AM   #5
Yup..sorry...there are splice kits meant to be buried
I actually spliced & buried one at my last house
Old 06-13-2010, 01:05 PM   #6
I=E/R
a7ecorsair's Avatar
Could you elaborate a little on this
Old 06-14-2010, 10:46 AM   #7
Rewards Points: 308
Apologies. I don't even know why I brought up hand holes. They are really only handy for wires that are to short to splice back as they are. Direct burial splices are the way to go in either circumstance.
Old 06-14-2010, 12:37 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
hand hole aka in ground junction box. Generally a plastic or concrete box with no bottom in it to facilitate making joints in wire/cable.
splice in electrical box dmilne Electrical 2 02-25-2010 10:59 AM
50 Amp Circuit - Splice 6 Gauge Cable to 12-3? jodic Electrical 4 01-23-2010 12:10 PM
to splice or not to splice treedoc Electrical 4 01-19-2008 10:56 PM
Max number of wires you can splice together firemanpato Electrical 12 01-10-2008 06:46 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
