Splice 14-2 Into 12-2? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 10:35 AM   #1
Rewards Points: 358
Splice 14-2 into 12-2?
I was reading in a book if its 12-2 all spice wires must be the same. I just wanted to verify that this is correct as the book as quite old.
I am splicing a motion sensor porch light off a near by outlet and I seen the wire was white so I bought 14-2 but once I got to the wire I noticed 12-2 was printed on wire.
Its 48" from the outlet to the lamp if it makes a difference. I have no problem getting some 12-2 I just have it all completely wired (I also added a near by switch) with 14-2 and was just about to make the final connection last night.
cbzdel is offline   Reply With Quote
Old 05-17-2010, 10:37 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
You should stay with the same wire size. Using smaller wire means you HAVE to use a breaker sized for that wire, which is a waste since the circuit is already existing.
Do the right thing. Replace the wire with #12 and leave the 20A breaker in place.
Old 05-17-2010, 10:49 AM   #3
Rewards Points: 358
will do, thanks. doesnt hurt to double check with people whom have worked with this before
Old 05-17-2010, 11:26 AM   #4
Licensed electrician
Rewards Points: 3,654
Since you have #12 wire, there is a good chance that this circuit should not be used for lighting.
What circuit are you using to feed this light?
Old 05-17-2010, 11:34 AM   #5
#12 wire is OK to use for lighting under code
Canada only allows a 15a circuit for lighting, but I think #12 wire could still be used - especially on a long run for voltage drop
20a requires all #12 wire, 14g can only be on a 15a circuit
Old 05-17-2010, 11:44 AM   #6
I am aware that 12-2 can be used, but most of the time cost issues limit the use to only where required like the kitchen or bathroom receptacle circuits.
I did not what to OP to think that any circuit was acceptable as a feed for the lighting.
Old 05-17-2010, 03:09 PM   #7
Rewards Points: 358
Its a 15amp breaker.. maybe the guy had an abundance of spare 12-2?
It goes from a 15amp breaker directly to a wall box, inside that wall box there is the wire splits, one goes to a single outlet, the other goes to a switch, that switch controls two outlets in the ceiling, that is all. These outlets have florescent lighting plugged into them. (this is a detached shop)
So I have my light installed and a 14-2 wire going to a switch, then at the moment I have the other end temporary wired to a male plug and I have it pluged directly into the said GFCI outlet. All is working fine but I want the wires hidden in the wall.
Who knows who originally did the wiring, maybe its a fire waiting to happen
Any pointers would be great!
Thanks!
Old 05-17-2010, 03:13 PM   #8
I used to use 12-2 for some lights & a 20a breaker
Back when a roll was only $29
Is there a sub feeding the detached structure ?
Or just the 12-2 ?
Old 05-17-2010, 03:23 PM   #9
Rewards Points: 358
"sub feeding the structure"
I am new to electrical terms, but I believe so. At the house there is a very large breaker labeled shop, I dont recall the size, (there may be more than one as there are a few not labled) then in the shop there is a breaker panel as well. There are (3) breakers total if I recall correctly.
1 - for the above said circuit
2 - for 5 misc outlets along the walls
3 - a 240 volt outlet
splice in electrical box dmilne Electrical 2 02-25-2010 10:59 AM
50 Amp Circuit - Splice 6 Gauge Cable to 12-3? jodic Electrical 4 01-23-2010 12:10 PM
cable splice kit instead of juction box? pat72 Electrical 18 07-21-2008 05:12 PM
to splice or not to splice treedoc Electrical 4 01-19-2008 10:56 PM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
