Spindle Frequency? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2019, 07:37 PM   #1
Rewards Points: 14
Spindle Frequency?
I bought and installed a new 1.5kw water-cooled spindle with an inverter to run it. Inverter is https://www.valinonline.com/products/esv152n02txb . Now whenever I switch the spindle on, it triggers my limit switches (in Mach3) and I can only reset it when the spindle is not running. Would adding a line reactor to the inverter help? Spindle and limit switch wiring is all shielded and properly grounded.
I'm virtually at a standstill. Any help?
brandonmason is offline   Reply With Quote
Old 01-17-2019, 08:36 PM   #2
Rewards Points: 310
Re: Spindle Frequency?
How does a drive trip or actuate a limit switch?
Or are you starting it up with a command in place.
Limit switches are physical auxiliary devices and need motion to actuate them.
Your question does not make any sense to me.
If it worked before you worked on it. You did something wrong.
Old 01-17-2019, 11:24 PM   #3
Rewards Points: 1,314
Check Page 35 in your manual for code P166 Carrier Frequency. Try changing the carrier frequency to different values above and below the current setting.
Assuming your limit switches are standard micro switches, it's not likely that you're actually tripping the switches, but the inputs that the switches are connected to. (Are you using normally-open contacts?). The carrier frequency of the drive can cause noise that interferes with other electronics. That's why it is adjustable.
BrownEyedGuy is offline   Reply With Quote
Old 01-18-2019, 12:01 PM   #4
Rewards Points: 310
The carrier frequency is not going to affect any inputs or outputs.
Limit switches are not electronics and are only mechanical devices.
The carrier frequency is adjustable as to prevent motor noise and motor heating.
It has nothing to with I/O.
Old 01-18-2019, 12:08 PM   #5
Hmmm, I wonder what those limit switches are connected to?
Old 01-18-2019, 02:25 PM   #6
Rewards Points: 1,005
what model cnc do you have? need to ts to determine if it is actually actuating an input. can you find and bring up an I/O page to watch the inputs? if not, you may be able to follow the limit sw wiring to the controller, and see a respective led change state with the input. you can do that by moving the switch by hand and watching the board.
are you sure they are not the soft (programmed) limits being triggered?
recheck all of your wiring!
TimPa is offline   Reply With Quote
Old 01-18-2019, 08:08 PM   #7
Rewards Points: 310
PLC most likley
Andersen Spindle Pulls Out latenight Windows and Doors 2 11-13-2014 07:59 PM
tap spindle over rotates? skar Plumbing 0 04-08-2012 12:16 PM
Spinning spindle on my washing machine jwo Appliances 5 09-15-2011 05:14 PM
Doorknob attachment to spindle c2gene General DIY Discussions 6 10-26-2008 06:04 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
