Special Outlet Needed For Treadmill? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 01:45 PM   #1
Special outlet needed for treadmill?
I have been using the treadmill in the 110v outlet in our home. But I do notice fluctuations in the lighting when I start running.
I am wondering if folks who own treadmills install a dedicated power supply for it?
shuss is offline   Reply With Quote
Old 07-11-2010, 02:13 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a motor, when starting or loading, will draw a lot of current compared to a unloaded running current. Every time you take a stride and as your weight hits the belt, it will load the motor.
(BTW: don't take that as a comment about your weight. It happens with everybody)
I would check the current draw on the machine. It might benefit you to have a dedicated circuit BUT
there are a few things that even a dedicated circuit isn't going to change the could be causing the problem as well.
If you can find a circuit with absolutely nothing else on it (it can have 100 receps as long as nothing else is actually using the circuit), plug it into there and try it.
are you using an extension cord? If so, lose it.
Old 07-11-2010, 02:45 PM   #3
Bad neutral at or upstream of your panel.
Can be easily tested.
Old 07-11-2010, 03:25 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Most treadmills are a huge power draw and the manufacturer will almost certainly recommend or require a dedicated circuit. I have seen many with 20A cord plugs.
Old 07-11-2010, 05:00 PM   #5
nap
You talking to me?
nap's Avatar
please explain how it is easily tested.
Old 07-11-2010, 05:30 PM   #6
Something about a 1.21 gigawatt resistor.
Old 07-11-2010, 05:36 PM   #7
nap
You talking to me?
nap's Avatar
kind of what I am expecting.
while I appreciate yoyo's efforts and even sometimes his methods, he is always whipping out some unique testing method that is a bit , um, different than any method I have ever used or seen.
On top of that, tossing such things on a lot of DIY'ers, I suspect, just confuses the Hell out of 'em.
The Following User Says Thank You to nap For This Useful Post:
Jim Port (07-12-2010)
Old 07-11-2010, 07:15 PM   #8
should i be worried if i dont use a dedicated circuit?
You are right. The lamp dims everytime i take a stride. I am not that heavy either if i continue to use that outlet, would i be hurting the wiring or the treadmill in amy way?
It seems like the cost of having a dedicated outlet for the treadmill is almost the same as buying a new treadmill. any thoughts?
Old 07-11-2010, 07:28 PM   #9
Turn on an appliance that draws heavy current at 120v, like this treadmill. If the voltage on the other side of the neutral goes up at all, it's a bad neutral connection.
If the light problem is only on the treadmill branch circuit it could be a bad connection, e.g., an improperly installed or failing wirenut.
This
http://www.google.com/products/catal...wAg#ps-sellers
does the same kind of tests but it doesn't need huge resistors because it uses pulse testing.
If I had that humongous resistor I'd put it across my 240 v line and get myself on the evening news.
Old 07-11-2010, 08:24 PM   #10
nap
You talking to me?
nap's Avatar
I understand the human body is quite a resistor
Old 07-11-2010, 08:28 PM   #11
nap
You talking to me?
nap's Avatar
is the circuit you are using the same circuit the lights are on?
if they are, find circuit with nothing on it, plug it in and run. With the same lights on as before, do they dim?
Old 07-11-2010, 08:45 PM   #12
Yeah, "Old Sparky" puts 2400 VAC across unfortunate people and 4 A to 8 A flows. For a while.
How many of these dudes wired in parallel would it take to bring down PoCo?
Old 07-11-2010, 10:17 PM   #13
" Euro " electrician
frenchelectrican's Avatar
I have see Americian thread mill most of them will ask for delcated circuit dut the current drawage it can peak out 15 amp pretty easy this is true if you are running near wide open speed.
Most of European verison is not a major issue due they are on 240 volts but still.,, the same as Americian verison they want it on delcated circuit for best performace.
Merci.
Marc
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
drywall repair next to an outlet - advice needed... myke232 Drywall & Plaster 2 08-19-2009 12:25 PM
Outlet wiring dilemma Mac McCloskey Electrical 8 08-17-2009 06:38 PM
washer/dryer frying my outlet dontwannadiy Electrical 15 07-27-2009 11:52 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
