Speaker Wire Behind The Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 11:29 AM   #1
Rewards Points: 1,062
Question
speaker wire behind the wall
is 16/2 the correct kind of speaker wire i should run behind DW ?
thanks
Old 03-22-2010, 12:51 PM   #2
Rewards Points: 2,800
The wire has to be rated for in-wall usage. The rating pertains to flame retarding and not biodegrading after a few years.
The gauge depends on usage; some experts recommend 12 gauge for high powered stereo and home theater speakers where the run exceeds 30 feet. Eighteen gauge is probably the smallest you should go and that would be pretty much limited to background music or radio or intercoms.
You can use Romex, although if the end comes out from the wall and continues a few feet to the amplifier or speaker (as opposed to having binding posts or screw terminals on the wall), it looks ungainly.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
The Following User Says Thank You to AllanJ For This Useful Post:
amakarevic (03-22-2010)
Old 03-22-2010, 01:43 PM   #3
i think i will go with 14/2
Old 03-22-2010, 02:52 PM   #4
Master Electrician
Rewards Points: 5,082
Wire must be rated for in wall use.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Old 03-22-2010, 03:31 PM   #5
Use speaker wire rated CL3 for in-wall use, 16awg up to 10 feet, 14awg or 12awg up to about 30 feet.
DO NOT believe the hype that you need exotic cables such as Mons*** Cable.
Willis
williswires is offline   Reply With Quote
Old 03-22-2010, 10:42 PM   #6
Rewards Points: 422
You can get your wall plates wire ect here lots cheaper than the stores.
http://www.monoprice.com/products/se...speaker%20wire
http://www.monoprice.com/products/su...04&cp_id=10425
High Gear is offline   Reply With Quote
Old 03-23-2010, 06:39 AM   #7
I bought my spoeaker wire locally for less then that
Plus shipping a heavy spool is expensive, so check around 1st
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Speaker wire in walls LeviDIY Home Theater 12 11-07-2009 02:56 PM
in-wall speaker wire? radon Electrical 19 04-11-2008 08:28 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
speaker wire JAVAMAN Home Theater 4 03-12-2008 07:40 PM
