Sparks On The Neutral Wire In The Panel Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 05:01 PM   #1
sparks on the neutral wire in the panel box
what does it mean when there is sparking on the netral wire in the panel box?
brandyrepman is offline   Reply With Quote
Old 07-25-2010, 05:02 PM   #2
Electrician
Proby's Avatar
Loose connection.
Proby is offline   Reply With Quote
Old 07-26-2010, 04:29 AM   #3
Rewards Points: 1,192
Why is that panel cover off?
bobelectric is offline   Reply With Quote
Old 07-26-2010, 06:45 AM   #4
Rewards Points: 2,800
A loose connection needs to be tightened up (not with tremendous strength) otherwise the sparking will heat up and burn the area where it is and possibly damage the panel beyond repair.
Should you find a loose connection you might as well retorque (undo a quarter turn and then retighten to a specified degree of tightness) every screw and set screw holding wires in place. With a little practice you will get a feel for getting a firm tightness without looking like stripping the screw threads although they do make special screwdrivers that have a dial or readout showing how tight you are going.
Don't touch the big lugs where the feed wires come in from the meter; have an electrician tighten them for you.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 07-26-2010, 09:05 AM   #5
Probably because he was looking in there
Just like many people who DIY do
Old 07-26-2010, 10:45 AM   #6
Electrician
Proby's Avatar
I agree with Bob's sentiment. When I open a panel up I am required to shut it down or wear the proper PPE, and I have experience and training.
A homeowner should get some info before opening the panel, one wrong move with that panel cover or their hand and they could be in a world of hurt.
AllanJ said: "Should you find a loose connection you might as well retorque (undo a quarter turn and then retighten to a specified degree of tightness) every screw and set screw holding wires in place."
There is no mention of shutting the panel down or even the individual branch circuits. If the thread starter follows this advice with an uninsulated screw driver he will get shocked when tightening the wires landed on each breaker. If the thread starter doesn't even know that a sparking wire at the termination point is a loose connection, we can't expect him to know that some of the screws we tell him to tighten can kill him.
I don't mean to rag on anyone here, but I fear for the safety of people who might be a bit over their head. I feel DIYer's should not jump into a hot panel with unfused power before they have the basics down (at the very least).
Old 07-26-2010, 12:47 PM   #7
I=E/R
a7ecorsair's Avatar
I have to agree that sometimes there is not enough safety emphasized in some of the ideas presented on this forum. I'm not an electrician but I have worked around electricity and electronics for many years. I did work about 8 months as an apprentice before entering the Navy (1967) and since then, I've worked aircraft maintenance (400 HZ 3 phase), data processing equipment (100 amp 3 phase), and taught electronics troubleshooting. Safety was always first in these fields and while at IBM, we had to complete electrical safety training every year.
I do cringe sometimes when I read some of these posting and realize that the OP is out of his league in some of these projects.
a7ecorsair is offline   Reply With Quote
Old 07-26-2010, 12:58 PM   #8
Agree! If my panel box was sparking I'd turn everything off and call an electrician!! And I'm a hardcore DIYer
justinm001 is offline   Reply With Quote
Old 07-26-2010, 04:56 PM   #9
Since you say THE neutral wire, I hope you don't mean the MAIN big neutral wire from the utility. If you do, SHUT YOUR PANEL OFF IMMEDIATELY AND CALL AN ELECTRICIAN.
If you mean one of the branch circuit's neutrals tied into the neutral bus bar, shut off that circuit until it is repaired.
Willis
williswires is offline   Reply With Quote
Old 07-26-2010, 07:07 PM   #10
Totally screwed together
Yes, if your Neutral bus wire is sparking, shut it down and call for help. If that goes out, it's possible to make some 120v get powered by 240v instead!
xxPaulCPxx is offline   Reply With Quote
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
Help if it's not too late!! Cyndi Electrical 255 10-10-2008 09:18 PM
Panel Upgrades and Aluminum Wire Fearless Freep Electrical 17 10-02-2008 12:45 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
