Sorority House Light Fight - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 08:54 PM   #16
Rewards Points: 3,004
If the student bedrooms are not separately metered with separate panels under the control of the respective students then there does not exist any "equipment" that supplies an individual tenant space.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 10-01-2009, 09:15 AM   #17
This is a sorority house, so it is a tenent /landlord situation.
Has your daughter informed the house mother?
Repair is up to the owner of the house,be it the univerity,local chapter, or national.
If the house mother can not fix the problem, have your daughter talk to the chapter advisor, and inform them of a " security issue".
If that dose not work , you can contact "National" and advise them of a parental concern. It will be fixed.
I do repairs for 2 houses.
Tnut
tnut is offline   Reply With Quote
Old 10-01-2009, 11:34 AM   #18
J. V.'s Avatar
Rewards Points: 348
Originally Posted by MI-Roger View Post
210.25 (A) My assumption is that the circuit breakers or fuses supplying the exterior patio light fixture are located in an electrical panel that is NOT located in either of the two Sorority House rooms opening onto the shared patio. If the circuit supplying the exterior light also provides power to receptacles or lighting fixtures within the rooms, then the AHJ may have reason to require the exterior light circuit to be a dedicated circuit.
210.25 (B) Sentence #2 above applies here also.
Use of a dedicated circuit to power this light would avoid any code non-compliance, but would be cost prohibitive for a quick retrofit. A less costly approach could be to request the AHJ to approve a design assumption that the patio and both adjacent rooms opening onto the shared patio comprise a single dwelling unit.
But in the end, the cheapest approach is to replace the single pole switch with the correct 3-way switch so both rooms can have individual control of the light.
I agree. And you are correct that these rooms most likely are not individually metered. But, we do not know that for sure? Its somewhat interesting that someone would allow control from two rooms instead of one. I wonder if all the rooms are set up this way. There may even be a three way circuit installed and someone has come along and installed single pole switches. Since we cannot see for ourselves and the OP has abandoned the post I will defer and concentrate on other things. Very good discussion though.........Thanks John
If it worked before you worked on it. You did something wrong.
Old 10-01-2009, 11:39 AM   #19
J. V.'s Avatar
Rewards Points: 348
Tnut
Welcome to the forum. I agree someone is responsible, the question is "Who"? Since the lady (the OP) is gone, I am done with it.......John
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
