Sony Television Repair - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2008, 12:06 PM   #1
Hi. Does anyone have a good source for buying Sony television parts? I need a new Changer Antenna (AS-2F) for my KV-32FS17 set. The part number is 8-598-414-20 (or 859841420). I found the part on one website for $33.95, and I'm just wondering if that is the going rate.
Thanks.
DaveSteel is offline   Reply With Quote
Old 04-24-2008, 12:20 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
Thanks.
I gave up fixing TV's a long time ago when everything became a mass of plug in boards with SMD components. I imagine that the part number you have is from a Sony BOM/Schematic? If so, it's more than likely not a product that is manufactured by Sony but some other component/device manufacturer. You best bet is to get the physical/electrical specs. and go to one of the following places to search for a replacement:
www.mouser.com
www.digikey.com
www.mcmelectronics.com
These are my favorites for buying electronic goodies, components, etc.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-27-2011, 11:19 AM   #3
having problems with my sony kdf-60xbr950. tv will shut down after its been on for a couple of hours. get 6 red blinks from led . so i changed out the g-1 board, tv worked great for about 10 days, then same problem is back, so what would cause g-1 board to shut tv down ?
dogturkey007 is offline   Reply With Quote
