Somebody Please Help, FAN With Remote Problem - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 07:29 AM   #16
Licensed electrician
Rewards Points: 3,662
The black and white leads that you talk about are normally only the power inputs. There are still output connections to be made also.
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Remote Temp Sensor and zonal Room dsc522758 HVAC 1 10-25-2009 06:15 PM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
