Is This A Snap-In Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 02:07 PM   #1
Rewards Points: 2,068
Pic is of 100A Main Breaker, Mobile Home. Label on Cover panel: HOMC24UC / Square D
No emergency (still working), but may need to find one of these in the not-too-distant future. Home has a 15kw electric furnace that is currently burning out the 100A breaker at the meter outside. Park maintenance on the way as I enter this post. Outside breaker still on for the moment, but will be off again by sundown, no doubt, if that long.
Wondering if pics are enough for anyone to tell me what info I need to give when ordering one of these. Maybe the HOMC24UC Square D is enough? Our local electrical supplier just shut down (out of business) I just learned.
After I remove the two Hot legs from those lugs (terminals?), will this breaker just pop out?
justplumducky is offline   Reply With Quote
Old 01-08-2015, 02:35 PM   #2
Rewards Points: 1,832
Pics did not load.
Jump-start is offline   Reply With Quote
Old 01-08-2015, 02:37 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,614
HOMC24UC is the number for the cover.
Main breakers normally screw or bolt in.
Old 01-08-2015, 02:38 PM   #4
Oso954's Avatar
Rewards Points: 1,606
duplicate of JOED's post
Oso954 is online now   Reply With Quote
Old 01-08-2015, 02:45 PM   #5
Rewards Points: 1,192
To get by, I would turn off the 5 kw heater breaker to the furnace to drop load. Less heat is better than no heat. Then talk upgrade.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
justplumducky (01-09-2015)
Old 01-08-2015, 03:10 PM   #6
My apologies - got interrrupted with a phone call - just got off the phone. Here's the pics:
And when I grab the breaker to move it up and down just a little to see if I can tell how it's connected, the lugs (where the red & black hot legs connect), move along with the body of the breaker when I move it just a bit. Don't know if that conclusive evidence of course, but maybe?
Old 01-08-2015, 03:38 PM   #7
You have some code violations that are a bigger concern. Double lugging and no bond screw for starters...
Old 01-08-2015, 04:35 PM   #8
Oso954's Avatar
Shouldn't this mobile home panel be a sub panel to the meter panel with breaker ? No bond screw, with grounds and neutrals separated ?
Old 01-08-2015, 04:43 PM   #9
You are correct, mobile homes need to be 4 wire. I missed that part in the first post, thought it was a home panel.
In that case a separate ground bar is needed with the grounds moved over.
The Following User Says Thank You to Jump-start For This Useful Post:
Oso954 (01-08-2015)
Old 01-09-2015, 03:15 PM   #10
Thanks for you help and I'll let 'em know about the code violations, but at the moment, the breaker is the only concern. Anybody have an idea about how it removes?
Old 01-09-2015, 03:34 PM   #11
Oso954's Avatar
Who is them ?
If you are not the owner of the panel, you should not be in it.
Old 01-09-2015, 03:39 PM   #12
Who is them ?
Lol, Have good weekend!
Old 01-09-2015, 03:44 PM   #13
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,.... It Don't,.... It's the Main, in that box,....
If it comes out at all, it's alota unboltin' everything around it,...
It acts as part of the main panel,...
The Following User Says Thank You to Bondo For This Useful Post:
New Breaker installed- Main Breaker trips novy31 Electrical 14 10-30-2013 08:08 AM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
