Smoking Wall Outlet When Connecting Refrigerator Through An Extension Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2017, 09:24 AM   #1
Rewards Points: 4
Smoking wall outlet when connecting refrigerator through an extension cord
Hello, I have a small refrigerator. My voltage stabilizer wasn't working so i connected the refrigerator through an extension cord to a power outlet (stabilizer was not connected). Within a few seconds after I switched it on, I started to see smoke coming out of the wall outlet and the extension cord plastic melted a bit. Thankfully I switched it off and there wasn't any fire. The extension cord I used is a 10 meter round extension cord with a max rating of 10 amps. My refrigerator says that it draws 0.9a of current. So i'm not sure why there was a problem. Could someone explain to me why this happened. I'm not sure if I should try and plug it in to the outlet directly without the extension cord as I'm not sure if it is safe.
Also, I live in India and we recently had a major flood during which half of this refrigerator was submerged in water. I had it repaired and it was working fine for about 4 months before this happened. Below is a picture of my refrigerator plug.
mk2005 is offline   Reply With Quote
Old 04-04-2017, 09:56 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,208
Re: Smoking wall outlet when connecting refrigerator through an extension cord
It looks like the pin in the cord damaged and the connection to the wires inside the plug are partially broken. This causes heat and burning plastic.
The Following User Says Thank You to joed For This Useful Post:
mk2005 (04-04-2017)
Old 04-04-2017, 10:31 AM   #3
Rewards Points: 2,672
Perhaps. However, the heating damage appears to be around the large "Earth/Ground" pin, which, under normal circumstances, should not carry any current.
Hence, it should not get hot.
FrodoOne is offline   Reply With Quote
The Following User Says Thank You to FrodoOne For This Useful Post:
mk2005 (04-04-2017)
Old 04-04-2017, 12:45 PM   #4
Super Moderator
joed's Avatar
Not being familiar with that type of plug I did not know that was the ground.
It would still suggest that the ground is getting hot. The only way to get hot would be current flow through a bad connection. Perhaps there is some sort of ground fault on the unit. Or maybe heat transfer to the ground terminal through a poor connection on the receptacle. If the ground pin is up that would be more possible since heat rises.
Old 04-04-2017, 12:54 PM   #5
Rewards Points: 4
Thanks for your replies. I'm a complete noob at this and am getting somebody to look at it tomorrow. I'm just wondering if there are any specific questions I should ask them?
Old 04-04-2017, 04:01 PM   #6
Red Seal Electrician
Old Brian's Avatar
Rewards Points: 92
I would also have them check the receptacle, just in case. While it does look as though the heating is internal to the ground pin of the male plug, it's also possible that there is an issue with the female ground slot in the receptacle and the heat is transferring from the receptacle to the male plug.
You said that the refrigerator was flooded. Is it also possible that the receptacle was flooded?
Cheers,
Brian
Old Brian is offline   Reply With Quote
Old 04-04-2017, 10:28 PM   #7
dmxtothemax's Avatar
Rewards Points: 7,680
I would say you have currents flowing in your earthing system
that should not be there,
so it may not just be a problem with the fridge
so check everything carefully
Like he said there should NOT be currents flowing in your earth wire
The only time there should be currents in your earth wire
is when there is a fault !
maybe you have one ?
or a nearby neighbour even ?
dmxtothemax is offline   Reply With Quote
220 extension cord question.. kmyer74 Electrical 6 04-24-2012 03:46 PM
Safe to install new outlet without connecting ground directly to outlet? charliebarkin Electrical 5 04-16-2012 11:36 AM
Connecting a battery backup to an extension cord (or vice versa); safe? kev77 Electrical 2 03-19-2011 02:02 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 09:16 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
